Cav fuel pump leaking.
/ Cav fuel pump leaking. #1
Welsyng
Ih 474
Hallo.
My cav fuel pump is leaking from the big screw down at the bottom of the pump.
Is this something I can fix myself, or does the pump need to be sent to a mechanic?
I am unsure if theres some sort of rings I can change so it doesn't leak anymore, and I don't know if there are some springs or something I can break if I take the screw out
Sorry for my bad English 😁
/ Cav fuel pump leaking. #2
Welcome to TBN
Most inj pump repairs requires very knowledgeable technician or IP repair shop.
/ Cav fuel pump leaking. #3
Yes there is an oring that can be changed.. & yes, there are springs AND SHIMS in the cap..
U should get a KIT w/ the correct size oring.. 7135-110.. CAV/Delphi
Ty for the answers.
Will the spring pop out if I remove the screw? In other words is it easy to change the oring my self?
I am not a mechanic, but I have changed some springs in the filter system of the pump my self before, so I am not totally incapable.
Do you know what the small screw is for? And do I have to unscrew that one before I unscrew the big?
/ Cav fuel pump leaking. #5
Sorry but I don't know answer to your question.
Jim
Problem solved.
I took the screw out and changed the oring. The springs inside didn't pop out :)
I already had a reseal kit from previous repairs I made and there was an oring I could use
/ Cav fuel pump leaking. #7
Glad u fixed it.. keep the kit close by..
on those pumps, if u stop 1 leak another starts.. unless u do them all at once..
Loudo Trailers 20ft. T/A Utility Trailer (A64557)
Loudo Trailers...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
JOHN DEERE QUICK ATTACH PALLET FORKS (A64278)
JOHN DEERE QUICK...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
213087 (A64276)
213087 (A64276)
CASE CX160D EXCAVATOR (A65053)
CASE CX160D...
