cattle guard
/ cattle guard #1
Bandit2026
Ferrum, VA
Ford 8N, Kioti CK35
I want to build a cattle guard from wood. I think it would be easier than installing a commercial made from concrete and a lot cheaper. I'm thinking rough cut 2x8s spaced 4" apart. It will lay on solid ground. Anyone ever see any plans for such a thing? Are have anyone ever tried this?
Thinks
/ cattle guard #2
how long do you need it to last? cheaper once - maybe - but if you have to replace it 3 times vs. pipe....is it still cheaper?
/ cattle guard #3
You can sometimes find one used, even if you aren't in cattle country.
Bruce
/ cattle guard #6
Not sure 2x8's laying on solid ground is what I consider to be a cattle guard.:confused:
/ cattle guard #7
Been there done that. Fought trying to keep cattle out of yard with homemade guards for years. Never did have any luck. Used sawn locust 4x4 spiked to crossties across a hand dug drain about 3 ft deep. Put in concrete and no problems with cattle since. Horses will jump across them though.
Wish I had done concrete to start with. Worked many hours on the wood ones and never did have any results.
/ cattle guard #8
We used railroad ties on the farm to make cattle guards. We would use two across the road and three running with the road and then lay the others across them spaced 4" apart. In 40 years we had one cow that would cross it, all the rest behaved.
/ cattle guard #9
I think wood will be okay for a ATV or UTV only crossing.
More than that, probably won't last long.
/ cattle guard #10
Thanks
Where will it be used, main driveway?
WE went with 16' concrete, it was under $1000 and DOT rated for fire trucks. SI Precast Concrete - Agricultural Products
More pictures here: http://www.tractorbynet.com/forums/newreply.php?do=newreply&p=3702588
/ cattle guard
It's not a main access just something to get small tractor and atv into pasture from garage. Got lots of good timber from building that was torn down but may try to score some 3x10 bridge timbers.
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
24in pin on excavator tooth bucket (A61307)
24in pin on...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
