Category 3 / PTO
/ Category 3 / PTO #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Power Take Offs (PTOs) to operate Category 1 and Category 2 size implements are the same.
What about Category 3 PTOs?
~~~same size?
~~~same operating RPM? (540 RPM)
I should know this, but I do not.
Thanks.....
/ Category 3 / PTO #2
pto speed and size offerings are more along the lines of tractor hp abilities and imp needs. 540 will always be the same 1.375 x 6 splines and is typically only used in lower hp instances. The next step up in hp requirements goes to small 1000 which will always be 1.375 x 21 spline. After that then it goes to large 1000 and it will always be 1.75 x 20 splines. Cat III tractors can be either small 1000 or large 1000 as well as the implements but probably leans to the small 1000 side as cat III is not a terribly large offering in the ag world. Once you get into cat IV, etc then we start to see just large 1000 or no pto/three point at all.
/ Category 3 / PTO
Thank you. THANK YOU.
/ Category 3 / PTO #4
Cat 3 does not mean only 1000 rpm. Our 7720 Deere is Cat 3 and is either 1000 or 540, I believe by changing the drive shaft - the 1000 rpm shaft meshes with a different set of drive gears than the 540. Ours is only used on our 540 rpm baler so I don't know about changing it. Our Cat 2 M135GX Kubota is used on either a 1,000 rpm chopper or its 540 rpm backup so the tractor PTO output shafts get switched when necessary. The 540 chopper has a notice that the driveline is limited to 90 PTO HP so we need to run slower when using the backup chopper.
/ Category 3 / PTO
Thank you, MHARRYE.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2007 International 9400i T/A Sleeper Cab Truck Tractor (A64194)
2007 International...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
2012 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A65643)
2012 TROXELL...
Grizzly Bear Statue (A65583)
Grizzly Bear...
