Cat. 1 PTO output shaft profile.
/ Cat. 1 PTO output shaft profile. #1
ChuckT
Central Florida
Yanmar YM1510D
IIs there a significant difference between the profile cut on a Kubota tractor PTO output stub-shaft and others?
I have a Walterscheid PTO shaft that will fit on and release from a brand new Kubota tractor but will fit but NOT release when I use it on our Yanmar. Perhaps I've misunderstood but I thought Cat.1 on an ABC tractor was identical to Cat.1 on an XYZ tractor.
TIA
cvt
/ Cat. 1 PTO output shaft profile. #2
I didn't think Cat. I had anything to do with the PTO.
I thought it only had to do with the size and hole diam. of the lift arms of the 3pt.
/ Cat. 1 PTO output shaft profile. #3
Pto shaft on your Kubota is a 1 3/8" by 6 spline. Pto shafts also come in an 1 1/8 diameter and a 1 3/8 21 spline. The latter is commonly used on 1000rpm implements. If shaft diameter and spline count are the same on both, I would look for a burr on the output shaft of the Yanmar.
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2007 STERLING LT9500 (INOPERABLE) (A63569)
2007 STERLING...
JCT Flat Bottom Grapple (A64047)
JCT Flat Bottom...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
Harlo HP6500 (A60462)
