Case International 50C
/ Case International 50C #1
John7575
St. Louis Mo.
2014 Case International 50 C
Anyone out there with a50C. just bought mine and having problems starting it.
/ Case International 50C #3
Welcome also. there is a case Ih forums also might be a good place to ask about IH hope you get good results.:thumbsup:
/ Case International 50C #4
What seems to be the trouble? Having trouble starting could be a number of things, but it's likely a safety switch or loose wire somewhere in a new tractor like yours.
/ Case International 50C #5
Make sure she's getting fuel, crack open a bleeder line while turning it over,
give er a shot of either.
Tractor starts fine initially,but after a few minutes of use either won't start or very hard to start!
/ Case International 50C #7
Unfortunately it sounds like a wiring issue with heat being the culprit, or a fuel pump thats pooping out after a little run time. There are some good Case IH dealers in your area with great service centers. Sievers in Hamel IL, Ennis in Troy Mo are likely the closest.
/ Case International 50C #8
Yep, definitely a fuel issue.
