Case Ih C50 shifting problem
/ Case Ih C50 shifting problem #1
millwrightdude
Some times when shifting from forward to reverse it does not want to go. When it wont go I can shift it from high to low a few times and it goes. Other times it shifts like it should. Is there a way to fix this. The tractor only has 715 hrs. Should I post this in the Case IH section?
Well there is a cable that goes to the clutch pedal that I adjusted a little when I replace the tractor step it was attached too and now the tractor will start with the transmission range lever in gear but only the range lever not the speed lever. What have I done??? Be for it would not start unless both levers where in neutral.Now it will start with the range lever in gear. What needs to be done to fix this. This makes me worry that something might be wrong.I cant remember it both levers needed to be in neutral or just the one
2011 FORD F-550 SUPER DUTY (A67714)
2011 FORD F-550...
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
21ft. T/A Homemade Parade Float Trailer (A66736)
21ft. T/A Homemade...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
Steiner 48in Front Loader Tractor Bucket Attachment (A64553)
Steiner 48in Front...
