Case IH 885 PTO shaft R&R
   / Case IH 885 PTO shaft R&R #1
groundhawg
Huntsville, TX
I have a '90 Case IH 885 2wd no cab. I broke my 540 PTO shaft with a stump grinder and found out yesterday this is not an easy fix! The PTO gear is to big to fit out of the hole in the case and there is a snap ring on the back side. This requires removing top cover from rear axle/hydraulic housing to gain access.
If anyone has a shop manual or experience with this procedure and could offer some insight I would be very grateful! I am pulling sheet metal, fuel tank and rops now. Thanks!
   / Case IH 885 PTO shaft R&R #3
Sorry i couldn't help as I have no experience with your problem, but it sounds like you made it fine. I can understand your concern with doing a job with no experience or guidance. I've found that you just have to get started and it usually works out. Congratulations on getting it done.
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2019 Ford F-550 Truck 4x4 Crew Cab Palfinger PSC6025 3 Ton Crane Service Truck (A55973)
2019 Ford F-550...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
CASECO SERVICE BED WITH CRANE (A58214)
CASECO SERVICE BED...
NEW Woods 6ft Finish Mower (A56436)
NEW Woods 6ft...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
