Case IH 885 PTO shaft R&R
   / Case IH 885 PTO shaft R&R #1
groundhawg
Huntsville, TX
I have a '90 Case IH 885 2wd no cab. I broke my 540 PTO shaft with a stump grinder and found out yesterday this is not an easy fix! The PTO gear is to big to fit out of the hole in the case and there is a snap ring on the back side. This requires removing top cover from rear axle/hydraulic housing to gain access.
If anyone has a shop manual or experience with this procedure and could offer some insight I would be very grateful! I am pulling sheet metal, fuel tank and rops now. Thanks!
   / Case IH 885 PTO shaft R&R #3
Sorry i couldn't help as I have no experience with your problem, but it sounds like you made it fine. I can understand your concern with doing a job with no experience or guidance. I've found that you just have to get started and it usually works out. Congratulations on getting it done.
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
