Case IH 275 Loader Control Valve
   / Case IH 275 Loader Control Valve #1
Tractornewbie2
1989 Case IH 275
Need Help,
I have 1989 Case IH 275 with a Dual 105 loader. The loader valve has a broken valve and is leaking. I have replaced it with a Brand LSV22RFSTKA2b control valve. After installing my front loader worked fine, but 3pt hitch no longer works (Some times moves very slow with no load). After talking to Brand Hydraulic they said that I needed the Power Beyond part. For my Case I only see an Input and Output on my Hydraulic block. Any suggestions on how to get this to work?
thanks,
Newbie2
   / Case IH 275 Loader Control Valve #2
Is there a lever on your left side? If so try moving it and see if that does it.
Just a lever on right for 3 pt. Some times my 3 PT hitch moves slowly with no weight on it.
   / Case IH 275 Loader Control Valve #4
Some of the older IH had a lever on the left to switch the hyd flow from front to back. That is why I posted that.
   / Case IH 275 Loader Control Valve #5
Does the new valve have three lines connecting it to the tractor? If so, did it come with (or did you also order) the correct power beyond sleeve and install it when you hooked up the lines? My first guess is that the problem is somehow related to that.
The control valve has 3 connects. but tractor only has 2. I have not ordered the power beyond part yet since not sure this valve will work.
Couple photo, one show block and hoses that go to control valve.
   / Case IH 275 Loader Control Valve #8
You do not have the lever I was talking about.
   / Case IH 275 Loader Control Valve #9
Any pictures of the valve itself and how its hooked up?
Below is information from the controller valve and how I have it hooked up, plus information from Tractor service manual on hydrauli.
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2018 Gatormade 20+5 Gooseneck Trailer (A53472)
2018 Gatormade...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
