Case IH 255 Engine Stop Solenoid
   / Case IH 255 Engine Stop Solenoid #1
Norskie
SW WI
Cae IH 255
Thanks for any info provided. The 255 diesel no longer shuts off with the switch. I have to pull the engine shutoff cable. Previously I could hear the engine stop solenoid click when I turned the key on. That no longer happens. The solenoid has 12 volts on both connectors with the switch on or off. Even when disconnecting the battery and reconnecting it I don't hear the solenoid. Why is there 12 volts with the switch on or off? Does that mean the Control Timer Unit is bad? A bad solenoid wouldn't (?) explain the constant 12 volts. I am at a loss. Any help is greatly appreciated.
NOTE: Don't see how to edit. The solenoid apparently is good. If I ground the non supply side, the solenoid clicks. Does that mean the Control Timer Unit is not supplying a ground?
Found the problem was a blown fuse. The second from the left.
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
UNUSED JCT QUICK ATTACH 74" VIBRATORY ROLLER (A51244)
UNUSED JCT QUICK...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
