Case Dozer Questions
/ Case Dozer Questions #1
Adiredneck
Upstate NY
2006 Kubota L3400DT, Kubota L5240
I Had a dozer loaned to me. It's a Case 1150B.
This same dozer was used by a friend, and he said at one time, while trying to back up a decent incline, that it wouldn't move. Turns out it was low on trans. fluid. Does the transmission use the same fuid as the hydraulic system, like a tractor? I want to make sure she's topped off before I start using it.
/ Case Dozer Questions #2
It would be best to call Case. My Case 1845c skid steer calls for HyTrans, or 10w 40 with a qt of Case additive. Another Case machine, a trencher, says to use ATF or HyTrans for the hydraulics.
/ Case Dozer Questions #3
OOOPS... Does this dozer have a hydrostatic transmission ? Then count minus 25% to the life expectancy of the pump and motor... high pressure systems like hydrostatic traction drives are extremely sensitive to air pockets, and the cavitation it causes...
I wont buy it when i know this happened ;)
I believe so. No hand clutches. Two foot clutch/brake pedals and a foot throttle on the right. Dozer stops when you let off the throttle...
/ Case Dozer Questions #5
Should be a powershift... 1150's didn't get hydrostatic till the Kseries
after the fiat merger.
We started it up last night to start using it, and it wouldn't move.
Put 3 gallons of UTF (all I had left from the last fluid change in the Kubota) in it because the trans dipstick barely had any on it. I'm stopping at TSC to grab two 5 gallon containers tonight.
Thing has been beat pretty bad. It does push pretty good now, but we're keeping a good eye on the fluid levels.
The cylinders need to be re-packed. Tracks are worn pretty good. My dad has been running dozers for 30 years. He can do more with a beat up old machine than most could do with a new one.
We're gonna baby it & send it back home.
/ Case Dozer Questions #7
Sure sounds like that dozer is on the edge and I sure wouldn't want the trans to go out while it was on loan to me. Of course I have always been the type that if it broke while I was using it it was my responsibility to fix it.
MarkV
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A65643)
2017 FORD F-150...
2004 GMC Sierra 2500 (A66408)
2004 GMC Sierra...
F-150 4WD (A63689)
F-150 4WD (A63689)
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A65643)
2013 POLAR TANK...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
