Case Dozer Questions
/ Case Dozer Questions #1
Adiredneck
Gold Member
Upstate NY
2006 Kubota L3400DT, Kubota L5240
I Had a dozer loaned to me. It's a Case 1150B.
This same dozer was used by a friend, and he said at one time, while trying to back up a decent incline, that it wouldn't move. Turns out it was low on trans. fluid. Does the transmission use the same fuid as the hydraulic system, like a tractor? I want to make sure she's topped off before I start using it.
/ Case Dozer Questions #2
It would be best to call Case. My Case 1845c skid steer calls for HyTrans, or 10w 40 with a qt of Case additive. Another Case machine, a trencher, says to use ATF or HyTrans for the hydraulics.
/ Case Dozer Questions #3
OOOPS... Does this dozer have a hydrostatic transmission ? Then count minus 25% to the life expectancy of the pump and motor... high pressure systems like hydrostatic traction drives are extremely sensitive to air pockets, and the cavitation it causes...
I wont buy it when i know this happened ;)
I believe so. No hand clutches. Two foot clutch/brake pedals and a foot throttle on the right. Dozer stops when you let off the throttle...
/ Case Dozer Questions #5
Should be a powershift... 1150's didn't get hydrostatic till the Kseries
after the fiat merger.
We started it up last night to start using it, and it wouldn't move.
Put 3 gallons of UTF (all I had left from the last fluid change in the Kubota) in it because the trans dipstick barely had any on it. I'm stopping at TSC to grab two 5 gallon containers tonight.
Thing has been beat pretty bad. It does push pretty good now, but we're keeping a good eye on the fluid levels.
The cylinders need to be re-packed. Tracks are worn pretty good. My dad has been running dozers for 30 years. He can do more with a beat up old machine than most could do with a new one.
We're gonna baby it & send it back home.
/ Case Dozer Questions #7
Sure sounds like that dozer is on the edge and I sure wouldn't want the trans to go out while it was on loan to me. Of course I have always been the type that if it broke while I was using it it was my responsibility to fix it.
MarkV
4" Makita Disc Grinder (A62613)
4" Makita Disc...
TARTER 180 CATTLE SWEEP (A64277)
TARTER 180 CATTLE...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Glenco 20' Field Cultivator (A66408)
Glenco 20' Field...
