case 7020 no reverse
/ case 7020 no reverse #1
max583
Stormville NY
case/ingersoll 7020, Deere GT235
I have a ingersoll 7020 that has no reverse at rear wheels.I have been reviewing all the forums I could find on this.
I replaced the balljoint,banana plate,most of the drive control linkage that looked worn. With it jacked up,I have forward at rear wheels,
but no reverse.with it in 4wd I only have rear wheel spine in foward and only front wheel spin in reverse. I changed the fluid and filter,everything else
works great,backhoe ,loader ,steering ,so pump pressure shouldnt be a issue.It has 500Hrs.Its a great tractor. Im getting frustrated :confused2:any Ideas ? Thanks
/ case 7020 no reverse #2
Did you work on the front diff ?
Sound to me the the front diff was assembeld upside down ?
No work done to the diff. Reverse at the rear wheels is a low power,almost none. In 4wd just the fronts work in reverse not in forward. Any problems with control valves ?
Finally fixed it.. Check valve for the hydraulic drive system stuck,took apart and freed up ,good to go.
4wd works ,and reverse working.
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
John Deere S350 (A60462)
John Deere S350...
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
John Deere 6320 (A64126)
John Deere 6320...
2023 Schulte FX3118 Batwing Mower (A66285)
2023 Schulte...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
