case 7020 no reverse
/ case 7020 no reverse #1
max583
Stormville NY
case/ingersoll 7020, Deere GT235
I have a ingersoll 7020 that has no reverse at rear wheels.I have been reviewing all the forums I could find on this.
I replaced the balljoint,banana plate,most of the drive control linkage that looked worn. With it jacked up,I have forward at rear wheels,
but no reverse.with it in 4wd I only have rear wheel spine in foward and only front wheel spin in reverse. I changed the fluid and filter,everything else
works great,backhoe ,loader ,steering ,so pump pressure shouldnt be a issue.It has 500Hrs.Its a great tractor. Im getting frustrated :confused2:any Ideas ? Thanks
/ case 7020 no reverse #2
Did you work on the front diff ?
Sound to me the the front diff was assembeld upside down ?
No work done to the diff. Reverse at the rear wheels is a low power,almost none. In 4wd just the fronts work in reverse not in forward. Any problems with control valves ?
Finally fixed it.. Check valve for the hydraulic drive system stuck,took apart and freed up ,good to go.
4wd works ,and reverse working.
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
Power command Transfer Switch (A62679)
Power command...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2023 Wolverine DM-13-72W Mulcher, Skidsteer Mount (A62679)
2023 Wolverine...
Speed Trailer (A64194)
2022 EZ-GO ELITE...
