Case 580CK Steering fluid replacement
/ Case 580CK Steering fluid replacement #1
serf2
Douglassville Pa
Case 580 CK
I just recently bought a Case 580CK and the power steering fluid looks milky as if water had gotten into it. I would like to drain the system and replace the fluid this weekend. Does anyone know what would be the best way to drain the entire system? I've ordered a service manual but do not believe I will have it by the weekend. I appreciate any info anyone may have.
Thanks
/ Case 580CK Steering fluid replacement #2
I have a 580B - you should be able to disconnect both hoses at the steering cylinder and drain most of the fluid into a bucket -
Then maybe find a rag or other way to seal an air hose around the filler tube on the pump and blow it down (probably messy) -
Then jack the front of the tractor up til the front wheels are clear, put the bucket under the steering cylinder (hoses still off) and manually push the tires to move steering from lock to lock (stroke the cylinder)
- Shouldn't be much left in the system after that... Steve
2020 ISUZU W4500 4X2 S/A  16FT BOX TRUCK (A59912)
2020 ISUZU W4500...
Claas Lexion 700 Series Folding Grain Bin Panels (A63117)
Claas Lexion 700...
1963 Ford Falcon (A62613)
1963 Ford Falcon...
2008 Ford Expedition SUV (A61574)
2008 Ford...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
