Case 580 ck backhoe "conversion"
/ Case 580 ck backhoe "conversion" #11
Bukitcase, great post!!! The pic is priceless!!!
I'm betting these units are hard to find?
/ Case 580 ck backhoe "conversion" #12
Yes on the great post!! Just what the op needed to know :thumbsup:
I'll shut up now.:D
/ Case 580 ck backhoe "conversion" #13
That's not a conversion, that's just switching attachments. :D
Bruce
/ Case 580 ck backhoe "conversion" #14
"That's not a conversion, that's just switching attachments"
True, but how many "attachment swaps" require a couple 1-1/2" wrenches, 4 feet of pipe, and 2 "bolt/clevise" pieces that require 450 foot pounds of torque? :D
/ Case 580 ck backhoe "conversion" #15
"I'm betting these units are hard to find? "
Probably so Richard - I haven't used mine since I got a couple other used tractors - but lately I've been eyeing it with evil thoughts running thru the "mad scientist" section of my brain - after a few more projects get either done or scrapped, I'm gonna look at the possibility of converting it to a FRONT HITCH for one of my "loaderless" tractors, so I can put a quick hitch on the front for non-pto stuff - seems that, with age, my head is even LESS fond of trying to rotate as far as Linda Blair's (Exorcist, in case nobody remembers)
Anyway, extending frame rails shouldn't be a problem but beefing front axles may change my mind... Steve
(The UP side, if it works at all - definitely will NOT need other front weights for ANY implement that tractor can pull - did I mention these beasts are HEAVY??!? I doubt if ANY part of that "adapter" is thinner than 3/4" steel other than a couple of small "thinner" 1/2" parts - I'd guess the unit weighs around 5-600 pounds WITHOUT anything attached)
/ Case 580 ck backhoe "conversion" #16
I LOVE Linda Blair. A real head turner!
Terry
/ Case 580 ck backhoe "conversion" #17
Steve, Europeans have had a "3pt" hitch on the front of their FWA tractors for a long time. I say go for it!!!! Would be awesome, especially if a Quick Hitch was adapted to it. Easy pick up of a weight rack, non-angle dozer blade, etc. :thumbsup:
Freightliner Columbia (A61307)
Freightliner...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
PREVIEW DATES AND TIMES (A61166)
PREVIEW DATES AND...
