Case 45 hydratatic
/ Case 45 hydratatic #1
Shannon14
Walhunding, Ohio
Farmall 45d
Need help. I have a case 45d with hydrostatic drive. Recently the tractor started to bog under load. It will idle with no problem but as soon as I put it in hi or low range or try to move it will stall. Issue is very inconsistent but is getting worse. Any suggestions would be greatly appreciated.
Have you checked the fuel filter?
I did. I replaced the fuel filter and did an oil and hydro change with all filters. Turned out to be a clogged gas cap. Cleaned out all vents and ran it for an hour with no problems! Thanks for the suggestion
/ Case 45 hydratatic #4
Had a friend that had a similar problem with his 500 hp Case/IH Steiger. Kept clogging the fuel tank vent. Took a large pair of channel lock pliers to get the cap off and when we did, it sounded like it was going to suck in anything within a 300' radius. HAHA Glad you got it fixed.
Gooseneck Stock Trailer (A64047)
Gooseneck Stock...
1997 LEDWELL 48FT DOVETAIL TRAILER (A63569)
1997 LEDWELL 48FT...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
2012 WESTERN STAR  4900SA  SLEEPER (A63569)
2012 WESTERN STAR...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
