Case 444 fuel pump
   / Case 444 fuel pump #1
toad430
Dunlap,Il
case 444 and 646
I have a case 444 and lost fuel pressure. I replaced the pump but can't get it to prime and pump. Is there a trick to priming a gas fuel pump on a Kolher 14 hp engine in a old case 444?
   / Case 444 fuel pump #2
No trick to it. Is the pumps lever riding on the cam properly?
Can you get fuel through the line to the pump? Some gas tanks have a screen filter inside the tank, sometimes attached to the petcock.
   / Case 444 fuel pump #3
If you pour a little gasoline directly into the carburetor, the engine should start and the pump will kick in.
   / Case 444 fuel pump #4
The K321 engine has a mechanical pump that shouldn't need priming. I've rebuilt a couple of these motors including replacing pumps and have never had to prime one.
I'd check fuel lines for a good flow and also for dry rot/cracks.
Here's a site with tons of info on the Kohler engine, the page linked has info on your fuel pump Information about the Kohler Carburetor, Various Fuels and Fuel Systems
I recently replaced the fuel lines and there is no petcock. when I dip the fuel line lower than the tank no fuel comes out so tomorrow I will disassemble everything and check for a pinch or blockage. Thank you
Thank you for all of the ideas. I will start tomorrow working my way through them and will keep you all posted
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
UNUSED JCT HYD HD BACKHOE ARM (A51248)
UNUSED JCT HYD HD...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
