Case 430ck
/ Case 430ck #1
swallow
Greenville,NY
case
The steering wheel doesn't turn the wheels in either direction. Something is wrong with the power steering hydraulics. Also my left steering hyd. cylinder leaks bad. Thank you for any help.
HTML][/HTML]
/ Case 430ck #2
Just sounds like it's low on fluid. If the cylinder has a bad leak, doesn't take long to empty the pump reservoir It only holds about a quart, if that.
/ Case 430ck
Thanks for replying DJ54. The reservoir is up to the full mark on the dipstick. It was very low on fluid and when I topped it off, the fluid looked foamy kinda like emulsified oil. I have not raised the wheels off the ground yet so I guess I will try that. The last time I drove the tractor, the steering seemed balanced, that is, the wheels turned equally in both directions. Could it be that the manual pump at the steering wheel is void of fluid? I am trying to find out what I should do first before I start tearing the system apart. I hate the thought of removing the distributor to get at the filter because I just timed it to 4 degrees btdc and it is purring like a kitten. I'm 70 and it is getting hard to get down under the tractor. Does it make any sense to remove the leaking cylinder first to check fluid flow or pressure? Thanks for any help. Walt
/ Case 430ck #4
You might try cracking the lines at the cylinder. But if it leaks bad, you may want to get it rebuilt. They did make seal kits for them. DIY, or take it to a good hydraulic repair shop. You don't even want to know what NOS cylinders are going for..., but I'll tell you anyway. Last one I saw, was over $1300.00..!!
2020 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 KENWORTH T680...
2022 EZ-GO ELITE...
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
Chevrolet Tahoe SUV (A64557)
Chevrolet Tahoe...
2011 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2011 Caterpillar...
