Case 1840 Odd Boom Lift Issue
/ Case 1840 Odd Boom Lift Issue #1
r8f1k
Farmall 100, Allis Chalmers D14, International Super MTA, IH 560, Mahindra 4510, Gehl 4500, Clark CY45, JD 800, JD 60
I have a Case 1840, serial number: JAF0312660*, pretty sure it is a 1999 model year and it has a strange issue when trying to lower the boom. I just bought it, so I am not used to these controls and maybe that is the issue. When you use the left handle, it should raise and lower the boom. It will raise no problem, but it will not lower the boom unless you move the RIGHT handle into the correct 'spot' and then it will lower. The machine is in good shape, 5700 hours and seems well maintained. If there is an adjustment or common issue with these, I am all ears.
2009 Jaguar XF Sedan (A61574)
2009 Jaguar XF...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
4x9 Homemade Utility Trailer (A62613)
4x9 Homemade...
