3-Point Hitch Case 1394 3 point not working
   / Case 1394 3 point not working #1
BCmetalman
Prince George B.C.
Kubota M9000
Hello all, I'm a new member here, hoping someone can offer some suggestions;
I just bought a Case 1394 (mid 80's, diesel, 65 pto h.p.) She's a little rough cosmetically, but runs good, and the loader works well, with plenty of lifting power. I have a manual on the way via ebay, but meanwhile.........
My problem is the 3 point hitch lower arms will not go up. They are in the 'down' position, and I can lift them up by hand, but
when I pull back on either of the control levers, the engine bogs slightly but nothing else happens.
Any ideas?
Thanks.
   / Case 1394 3 point not working #2
Check if the linkage from 3 point lever is connected to the valve. Also if for some reason your 3 point hydraulic is plumbed after loader or remote outlets the loader and remote control valve has to be in neutral position for 3 point to work. Normally 3 point is plumbed first and remotes and loader from power beyond so this is just a unlikely possibility.
Hi R.i.t. thanks for replying.
Your suggestions give me a starting point, so I will look at those first.
Will report back.
Regards,
Toby
   / Case 1394 3 point not working #4
My 1494 has a small push/pull rod left side of the seat that diverts hydraulic fluid or isolates it to the loader. Sometimes it gets knocked into the wrong position and I think there is a problem until I recycle that rod.
Thanks for the idea, I will check that too.
Hoping to have a look at the tractor tomorrow if time permits, will advise.
BCmetalman
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
