Carrying Tools
   / Carrying Tools #21
For the OP - do you have large rube that runs side to side?
Put a thin wall plastic pipe with caps down it.
Mine is big enough for some wrenches, screwdrivers etc. The rest go in an old laptop bag behind the seat.
   / Carrying Tools
Yes, actually I posted this pic in a different thread. PVC Wont fit without severely reducing the usefulness. Electrical conduit will fit a bit better as another pointed out but still reducing the already limited size. To make it more useful by using the conduit I would need several pockets and need to get creative to cap each one in limited space and to be able to pull then out. I just have it plugged for now and will probably just store chain or two. It's an option but I would be without anything in it when bushogging with the FEL detached.20181128_172851%20(1).jpeg
   / Carrying Tools #23
Ammo cases make pretty good toolboxes. A Mil std case will be water-tight as well. There should be somewhere on that tractor you can mount it.
   / Carrying Tools #24
Insert into the 4" round pipe of the front end loader? It sounds like some guys on here are using 4" plugs to store things in there such as chains.
   / Carrying Tools #25
I have used different mounted toolboxes but have found a ammo box style is the best. They are compact ,cheap,durable and waterproof. The only negative is that they are not as long as a normal toolbox. I had to cut the handle down on the hammer that I keep with me.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
TANK MANIFOLD (A58216)
LONG 2460 TRACTOR (A58374)
LONG 2460 TRACTOR...
