Forks Carry All Fork
/ Carry All Fork #1
DennisY
Maine
JD 850
Well, I found what I was looking for at Northern Tractor. It is a Howse carry all fork for use with 3ph for only $59.00. The only problem is they tell me that it will cost about $90.00 to ship it to where I live (Maine). We have always said that we were at the end of the road here and I guess that proves it! Any ideas other than check with some equipement dealers within a reasonable driving distance?
/ Carry All Fork #2
i have bought them at central tractor and quality farm and fleet for about 60 bucks, any of those in your area.
good luck
al
/ Carry All Fork #3
Or is there a Tractor Supply Co. store in your area. They also have them.
Bird
/ Carry All Fork #4
Does anyone have a website address for Quality Farm and Fleet. I too have been looking at the Northern carryall fork for $59 (they want $81.50 to ship to me). I would gladly spend the money, but the Northern item has a 500# capacity. I'm thinking that for the same money, I might find a heavier model elsewhere. I'm like the Maine resident-you can't get anywhere from where I live, and all shipments come by pony express.
/ Carry All Fork #5
Dennis,
Maybe it would be cheaper if you could find a welder in your area.
Thomas..NH /w3tcompact/icons/wink.gif
/ Carry All Fork
Thomas,
Your idea may well be the most pratical solution.
/ Carry All Fork #9
Do you have a VO-Tech school anywhere close? I live right up the road from one and they are mighty handy and all it cost is the material to make whatever you're working on.---Cliff
/ Carry All Fork #10
Yes we do, but I also weld a bit myself. I have found out one thing pretty fast. To make a tractor implement that will stand up to use, you should try to avoid using simple mild steel and instead look for some tempered cold-rolled steel. This is the problem. In my area, cold-rolled tempered steel often costs almost as much as just buying a used or cheap implement. Maybe someone has a suggestion on what else to use that is economical.
/ Carry All Fork #11
friend of mine welded a pallet jack to a plate that he could attach to his bobcat used it to move skids of fire wood, seemed to work ok.
alex
John Deere 230 Disc Harrow (A66285)
John Deere 230...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2010 ALTEC DIGGER DERRICK (A59914)
2010 ALTEC DIGGER...
2022 EZ-GO ELITE...
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
Skid Steer Deluxe Hitch Plate (A65640)
Skid Steer Deluxe...
