Caroni Flail Belt Failure
   / Caroni Flail Belt Failure #221
According to this exploded diagram , you don't even have to remove the rotor . It looks like there are bearing caps that are simply withdrawn from the outside to service the bearings and seals .
You know I was unsure if one or both of them was in floating position because of the exploded diagram and neither one would have to be set with a fixed bearing race because of the compression spacers used for them
it does make it easier for sure.
:thumbsup:
By the way , if it was air trapped in a grease gun , it would not have made a noise . The gun would simply not work because of the air , so could not pump air to make a noise .
true, very true, I have had grease that hated pins and the pins hated the grease they were so tight- volvo loader boom and bucket pins and you did hear small pops greasing these with the power greasers sometimes.
well time to go to bed iron horse -throw a few shrimp on the barbie for me as i have to go to town in four hours - I would send some wine to you but a cohort in queensland told me i would end up visiting the local jail there where he is if i sent him some by UPS.
nite all
   / Caroni Flail Belt Failure #222
Just chiming in..... I cooked my belts last night too.....
Off to NAPA!!
-Jer.
   / Caroni Flail Belt Failure #223
Here is what you need:
   / Caroni Flail Belt Failure #225
That link doesn't take me to a specific item.
Gates B43 single belt x3 is basically what you need.
   / Caroni Flail Belt Failure #226
3 Gates B43's, $50, and about 10 minutes later, I'm back in business.....
The belts were a bit tough to find, but I found 'em eventually.
Big thanks to whoever figured out the Caroni to Gates conversion, and to Island for his pic!!
I cranked the tensioner almost all the way, is that OK??
-Jer.
   / Caroni Flail Belt Failure #228
Here's a snapshot. I don't see Gates mentioned is why I'm asking.
attachment.php
   / Caroni Flail Belt Failure #229
There are a lot of companies that make B43 belts. I don't know who NAPA uses. Gates is a premium brand and given the issues with belt failures with the original Caroni supplied belts, I would recommend paying a couple of bucks extra (each) for the Gates. If you look at the photo I posted I think you can see the distinctive name (power something or another). These are just basic good Gates belts. They make even fancier types but I haven't had any trouble with the plain vanilla Gates.
   / Caroni Flail Belt Failure #230
Follow up to the "pop, pop there goes the seal" subthread. It appears that I may simply have been displacing some air in the seal or so my tractor savvy neighbor thinks. I've mowed the 8 acres I needed to get done before putting in the fencing to improve my sheep pasture and no problemo so far with anything overheating. PLUS I got a spiffy laser guided IR thermometer out of the deal to boot.
As to belts, I thought I was getting Gates but instead found I was getting Kevlar enhanced Pix B43 belts. Kaman Industrial Technologies swears by them and claims that's what they put on all their machinery, we will see. I will put them on after I go through the replacement set I got from Agri Supply and report back to the group.
As of now everything seems good except I'm about 2 weeks behind on getting things shut down and prepared for winter.
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
DEL MORINO VICTOR FLAIL MULTCHING MOWER (A58216)
DEL MORINO VICTOR...
John Deere 4600 (A53317)
John Deere 4600...
3ft Teakwood Totem Pole (A57454)
3ft Teakwood Totem...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
(50) UNUSED FUTURE 3'X12' CORRUGATED METAL SHEETS (A58376)
(50) UNUSED FUTURE...
