Caroni Flail Belt Failure
   / Caroni Flail Belt Failure #241
Yet another data point.
Suffered catastrophic belt failure (all three) yesterday. All of them twisted, melted, shredded and snapped. Significant melted/hardened residue on the tensioner. Not sure of exact hours, but I've only a single 50 hour engine oil change since purchasing the unit last year, and mowing is the minority of my use. Probably less than 20 hours on the Caroni.
These were the original belts, and mowing conditions were far from severe - I've mowed through much taller/wetter material with ease. Mostly dry field grass, max 24" height, most much lower.
On the "perhaps I share some responsibility" front - while I've shot a couple pumps of grease in each zerk every time used and kept the gearbox full, I've never had the belt cover off to inspect or adjust tension. Given that all three belts were destroyed, I can't say where things were prior to failure. Also, I did notice while mowing that things seemed a bit off for 10 minutes or so prior to failure...there was no belt squeal I could hear, but it did seem to be down on cutting power a bit. The m0wer was lugging somewhat in grass/conditions that I recall it having zero issues with before.
No obvious problems upon taking things apart - everything spins freely, no excess grease residue, etc.
New belts on the way - unsure of the brand, but found some for $27 delivered via Amazon. Everywhere local wants $17+ each, Gates or otherwise.
________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________________
I hope the curse of the "A" boats has not moved inland!!!!!!!!!
I think you had a loose belt situation which melted the V-belts due to being
loose and having a poor grip on the pulleys.
The V-belt snubber would have been of no help because it is tensioned manually.
The green kevlar belts of this size were under ten bucks the last time I bought one for
my Mathews Co. Lawn Genie at NAPA.
Be extra carefull with the new belts and be sure that they are of the same lot number before
you install them because each lot number is different in that each run of man made nylon thread
is different.
   / Caroni Flail Belt Failure #242
A lot of us had fairly early belt failure but my replacement set of Gates belts have lasted at least 3 or 4 seasons now without incident. I did tighten the tension as much as I could after the initial failure. Hard to get the tension much beyond half inch deflection.
   / Caroni Flail Belt Failure #243
Reporting in with a catastrophic belt failure on my 73" Caroni flail.
I had 16 hours on the tractor and 10 hours or so on the flail.
I hope to find some belts locally in the morning so I can mow all day tomorrow.
Thanks to the posters in this thread with all the info.
   / Caroni Flail Belt Failure #244
I just saw this now-
Kevlar belts at TSC or NAPA BE SURE THE BELTS WITH THE SAME LOT NUMBER!!!!!!!!!!!!!!!!!!!!!!!!!!
Kaman bearing for two Web V Belts
   / Caroni Flail Belt Failure #245
Ordered 6 belts from here: B43 V-Belt - $3.55
$3.55 each.
Six belts plus shipping($11.50 for UPS Ground) was $32.80.
Couldn't find any local on a Sunday so I'll roll the dice on some cheapies. When I smoke one set I'll order some Gates belts for a back up.
   / Caroni Flail Belt Failure #246
The proper belt probably costs more than all 6 of the cheap belts. You want to run a flail mower with a $3.55 belt? :duh:
   / Caroni Flail Belt Failure #247
That's probably the same quality as the factory supplies. Odd, because the mower is not cheaply made but almost everyone burns up the original set of belts in the first season or so.
   / Caroni Flail Belt Failure #248
Anyone have the correct # for the Gates belt. I have about 50 hours on my Caroni and the belt is fine so far but I want to have a spare.
   / Caroni Flail Belt Failure #249
Did you read what I posted?
No local belts available on a Sunday.
I ordered some cheapies to try.
I'll use the first set, and when they break I'll install the second set and order a set of Gates to have on hand.
If the cheapies work I win.
If they don't, I gambled $3.55 per belt.
   / Caroni Flail Belt Failure #250
B43. You need three of them.
Meyer 8.5' Snow Plow w/ Bracket (A55272)
Meyer 8.5' Snow...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
International DT466 Fuel Truck (A55272)
International...
2016 PETERBILT 389 FLATTOP (INOPERABLE) (A58214)
2016 PETERBILT 389...
PALLET OF CARBURETORS & PARTS WASHER (A58374)
PALLET OF...
2018 John Deere 652R QuickTrak 52in Stand-On Commercial Mower (A56857)
2018 John Deere...
