carb problems
/ carb problems #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
56 800 Ford.Carb floods immediately when i turn on the fuel.Adjusted the float several times but did not solve the problem.All comments will be appreciated.
/ carb problems #2
The needle valve is probably stuck or there is a piece of crud in the seat. A little carb cleaner should do it. Good luck.
/ carb problems #4
Im with the others. Definitely the needle valve or the float. I would recommend getting a rebuild kit for it. Some needle valves have a very tiny rubber o ring around them that will dry out and will continue to let fuel though.
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2017 MAC Half Round T/A End Dump Trailer (A64194)
2017 MAC Half...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
