carb problems
/ carb problems #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
56 800 Ford.Carb floods immediately when i turn on the fuel.Adjusted the float several times but did not solve the problem.All comments will be appreciated.
/ carb problems #2
The needle valve is probably stuck or there is a piece of crud in the seat. A little carb cleaner should do it. Good luck.
/ carb problems #4
Im with the others. Definitely the needle valve or the float. I would recommend getting a rebuild kit for it. Some needle valves have a very tiny rubber o ring around them that will dry out and will continue to let fuel though.
New/Unused 20ft X 20ft Steel Carport (A65583)
New/Unused 20ft X...
Barrel (A64557)
Barrel (A64557)
Willmar Wrangler 4500 Loader (A66285)
Willmar Wrangler...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
