carb problems
/ carb problems #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
56 800 Ford.Carb floods immediately when i turn on the fuel.Adjusted the float several times but did not solve the problem.All comments will be appreciated.
/ carb problems #2
The needle valve is probably stuck or there is a piece of crud in the seat. A little carb cleaner should do it. Good luck.
/ carb problems #4
Im with the others. Definitely the needle valve or the float. I would recommend getting a rebuild kit for it. Some needle valves have a very tiny rubber o ring around them that will dry out and will continue to let fuel though.
2017 DITCH WITCH JT20 DIRECTIONAL BORING MACHINE (A63276)
2017 DITCH WITCH...
2023 Tesla Model 3 (A64557)
2023 Tesla Model 3...
40300SFL (A64557)
40300SFL (A64557)
2022 EZ-GO ELITE...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
KOEHLER GAS POWERED GENERATOR (A64278)
KOEHLER GAS...
