carb problems
   / carb problems #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
56 800 Ford.Carb floods immediately when i turn on the fuel.Adjusted the float several times but did not solve the problem.All comments will be appreciated.
   / carb problems #2
The needle valve is probably stuck or there is a piece of crud in the seat. A little carb cleaner should do it. Good luck.
   / carb problems #3
If the float is water logged or a hole in it your not going to be able to adjust it.
   / carb problems #4
Im with the others. Definitely the needle valve or the float. I would recommend getting a rebuild kit for it. Some needle valves have a very tiny rubber o ring around them that will dry out and will continue to let fuel though.
John Deere 6120E (A50323)
John Deere 6120E...
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2004 Cherokee Lite 28A 30FT T/A Travel Trailer (A51694)
2004 Cherokee Lite...
John Deere MX10 Rotary Cutter (A53117)
John Deere MX10...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
