Can't remove loader
/ Can't remove loader #1
Tig
Elite Member
The County, Ontario, Canada
Kubota, B7100HST-D
I have an LA300B loader on my B7100. It's detachable and looks like it should come off in about 5 mins. Problems is that the where the loader upright sits in the pocket on the left side of the subframe I have rust. :mad: Enough rust apparently to fuse the subframe to the loader upright. I am soaking the area in a 50-50 mixture of diesel and motor oil. I have used a hydraulic jack to push them apart. It didn't budge. Has anybody got any ideas on how to get them apart? I am trying to be patient before I use heat on the subframe.
I just found the "wax on rusted/frozen parts' thread. Sounds like that is my next step.
/ Can't remove loader #3
Post back if you don't have any luck.
I've found ATF mixed with Kerosene or diesel makes a good 'unstickem' too.
Soundguy
No luck with wax. I had to dis-assemble the one side of the loader to get it off. Then I removed the subframe. It was soaking in diesel and motor oil. I'll keep that up and see if it works loose over time..
/ Can't remove loader #5
remind me again why this isnt a great application for a big hammer!?
/ Can't remove loader #6
Try hitting it with "PB Blaster" penetrating oil - comes in a spray can. I've had pretty good luck with it - WalMart sells it.
JayC
Big hammer? Yeah, I tried that. I put a piece of 2x6 on the upright and splintered it with a 5lb sledge. I figured I'd quit while I was ahead.
I'll keep my eyes open for the PB Blaster.
/ Can't remove loader #8
I've switched to the penetrant GM service techs use. Heat pipe penetrant and antirust or similar is the name. The guys that twist bolts for a living use it when they need the nuts to come off. They only get paid a flat rate for the job as dictated by the book. Waiting for a bolt to work loose isn't in the cards!
You can only get it at a Chevy or GMC dealer. About 10 bucks and worth it.
jb
/ Can't remove loader #9
FWIW, I've had great results using PB Blaster. Just don't get it your eyes. :eek:
/ Can't remove loader #10
Any pics of area in question? Sounds like a hydraulic jack may be needed to help press things off/apart.
/ Can't remove loader #11
Harbor freight has good deals on porta-power type equipment now and then.. guess you could make a pipe bender out of it when not using it as a mobile press...
soundguy
Here is a couple pics of where the loader post is seized in the receiver on the subframe. Tried a 10T jack between the subframe and the loader arm. Nothing budged. I needed to get the loader off so I could do some repairs on the tractor. By disassembling the loader arm I was able to remove the loader and subframe and complete the repairs. Not urgent to get it apart now but I would like it to work properly in time.
/ Can't remove loader #13
There is always heat
I have not been very aggressive with heat. It's a big area to try to heat evenly.
/ Can't remove loader #16
I'm no Kubota expert by any means,
but my first thought is this:
does the mast lock into the reciever during
installation? I thought we had a similar
tractor in a few months ago, and I think
I remember removing some threaded rods from
the front leg of the loader, near the front frame
of the tractor,, which allowed that leg to
drop down using the hydraulics. that brings
the mast forward, and then up and out (once
the pins were removed) of the pocket.
Is your loader simlar?
again, just trying to help, and claiming no
bota expertise here
:D
/ Can't remove loader #17
I guess I was not really thinking about heating evenly. I was thinking that the heat plus the burning off of the petroleum products might cause the rust to flake off, break up and pop out of there. Good swing of the hammer to knock it loose. Not saying I am right, but it seems like I ran into some similar issues when I worked on the farm. Can it really hurt anything?
/ Can't remove loader #18
Tig,
I may be looking at the pics wrong, but is the locking pin still in the support for the upright? This pin keeps the rear of the loader from lifting when you pick something up in your bucket. I circled it in your pictures.
Mike
I put the pin back in while I was using the loader. That's when the picture was taken. I referenced the loader operators guide when I tried to remove the loader. The other side comes apart fine. I am leaving the pin loose while I use the loader just to give it an chance to wiggle a bit. So far nothing.
/ Can't remove loader #20
Cant you fasten the loader to something like a tree, and use the hydraulics to wiggle it around a bit, any movement will help to break the rust. You might even be able to lift the loader off using the hydraulics.
1977 FRUEHAUF  C35D-J2-42-6 LOWBOY EQUIPMENT TRAILER (A67714)
1977 FRUEHAUF...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2016 Toro ReelMaster 5510-D Commercial Reel Mower (A66734)
2016 Toro...
2012 HIDEOUT BUMPER PULL (A67714)
2012 HIDEOUT...
Toro Groundmaster 228D (A64912)
Toro Groundmaster...
2026 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A66734)
2026 KH72 72in...
