Can't keep it up!
/ Can't keep it up! #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
The 3PH, that is.
JD 770, less than 900 hrs. Bought it last winter. It appears that fluid changes had been neglected, but everything works fine except that the 3 pt. hitch drifts down. Lifts the loads OK, at least the ones I have put on it--4 1/2' disk with about a 75 lb. weight, 5' cultivator. Did not put a load on it before I changed the fluid & I used aftermarket fluid that was supposed to be approved for JD's. Now I am wondering if maybe this is the wrong fluid & if the wrong fluid could cause the problem. FEL works just fine.
So where do I start? New fluid? Is there a particular check valve that typically causes this problem? Any other suggestions?
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2019 John Deere 4044M (A62177)
2019 John Deere...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
New - Front mount rototiller
New - Front mount...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
2022 Sany SY215C Hydraulic Hammer (A62679)
2022 Sany SY215C...
