Can't just retube that
   / Can't just retube that
I'd put the tube inside of the tire after 1st bead is on, add a "little" air (just enough to give it a soft form), then careful not to pinch it, put the second bead on ...
That's what I ended up doing, took it back off, then put hte tube in, air, then back on.
   / Can't just retube that #52
I think you learned a lot about mounting a tire :rolleyes:
But the c-clamps might scratch the paint! :ROFLMAO:
They werent' tightened down, just hooked. I was thinking about regular rims, I would say furniture pads would probably work on the c clamp.
I did! And now I can say I've done it.
   / Can't just retube that #55
But guess what doesn't work!
I just had a new 600-16 front tire put on my rim yesterday; no way I'd wrestle with it myself @ 83. The new 600-16 6 ply tire was $117 including taxes, they used my old tube saying it appeared like new.
When I DIY years ago I did as Shawn said with one exception; after mounting you aired the tube to perhaps 20psi then let it deflate. Do that 2x to insure there's no wrinkles or folds, then air up to sidewall pressure.
Pinching a new tube is a bummer, patching it is humilitating.
As I'm half your age, I feel like I should at least make the attempt. But I'll say, if this doesn't work, I'll be placing my order for a new rim without hesitation.
I did inflate the tire, then deflate to make sure there weren't any wrinkles. Then I inflated to 6psi and bounced the tire around, 10 psi and repeat, 14 psi, and eventually 24psi. I feel like bouncing it got the bead to set into place properly with the various pressures. I was worried the extra material that I welded in would interfere with the bead, but I guess i grinded away as much as was necessary to let it set properly.
   / Can't just retube that #57
As long as it holds air, and goes "round and round" ... It's fine ... It's not like it's going on a Corvette! 😁
   / Can't just retube that #58
I think you did a great job. The only concern I'd have is with how the tube might wear a little near the edges of your repair plate. But I'm sure you did as good a job as possible with softening or feathering those edges, and could probably even add body filler later if needed. Probably not any short-term concern, unless the plate edges were left sharp.
Hey, speaking of which... anyone remember how they'd line a spoked bicycle wheel with a large rubber band or scrap of old inner tube, to protect the tube from the spoke adjuster t-nut heads?
   / Can't just retube that #59
Yup, and the old split rim style of semi-truck rims had a rubber liner too!
   / Can't just retube that #60
With that success, I think you're ready to move on to mounting a tire on a split rim wheel :eek:
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
CASE TV620B SKID STEER (A52709)
CASE TV620B SKID...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
telescope boom (A56857)
telescope boom...
