Can't just retube that
   / Can't just retube that
I'd put the tube inside of the tire after 1st bead is on, add a "little" air (just enough to give it a soft form), then careful not to pinch it, put the second bead on ...
That's what I ended up doing, took it back off, then put hte tube in, air, then back on.
   / Can't just retube that #52
I think you learned a lot about mounting a tire :rolleyes:
But the c-clamps might scratch the paint! :ROFLMAO:
They werent' tightened down, just hooked. I was thinking about regular rims, I would say furniture pads would probably work on the c clamp.
I did! And now I can say I've done it.
   / Can't just retube that #55
But guess what doesn't work!
I just had a new 600-16 front tire put on my rim yesterday; no way I'd wrestle with it myself @ 83. The new 600-16 6 ply tire was $117 including taxes, they used my old tube saying it appeared like new.
When I DIY years ago I did as Shawn said with one exception; after mounting you aired the tube to perhaps 20psi then let it deflate. Do that 2x to insure there's no wrinkles or folds, then air up to sidewall pressure.
Pinching a new tube is a bummer, patching it is humilitating.
As I'm half your age, I feel like I should at least make the attempt. But I'll say, if this doesn't work, I'll be placing my order for a new rim without hesitation.
I did inflate the tire, then deflate to make sure there weren't any wrinkles. Then I inflated to 6psi and bounced the tire around, 10 psi and repeat, 14 psi, and eventually 24psi. I feel like bouncing it got the bead to set into place properly with the various pressures. I was worried the extra material that I welded in would interfere with the bead, but I guess i grinded away as much as was necessary to let it set properly.
   / Can't just retube that #57
As long as it holds air, and goes "round and round" ... It's fine ... It's not like it's going on a Corvette! 😁
   / Can't just retube that #58
I think you did a great job. The only concern I'd have is with how the tube might wear a little near the edges of your repair plate. But I'm sure you did as good a job as possible with softening or feathering those edges, and could probably even add body filler later if needed. Probably not any short-term concern, unless the plate edges were left sharp.
Hey, speaking of which... anyone remember how they'd line a spoked bicycle wheel with a large rubber band or scrap of old inner tube, to protect the tube from the spoke adjuster t-nut heads?
   / Can't just retube that #59
Yup, and the old split rim style of semi-truck rims had a rubber liner too!
   / Can't just retube that #60
With that success, I think you're ready to move on to mounting a tire on a split rim wheel :eek:
2018 FREIGHTLINER M2 SINGLE AXLE DUMP TRUCK (A59575)
2018 FREIGHTLINER...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2025 Future 750 Remote Control Crawler Mower (A56859)
2025 Future 750...
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
WHITFIELD TREE PLANTER F853ETH (A58375)
WHITFIELD TREE...
