Loader Cant figure it out. hyd. Hose connection
   / Cant figure it out. hyd. Hose connection #1
CrestonNC
Creston, NC
Kubota L3800
I have a new grapple and can't figure how to connect the QD? Hydraulic hoses. I can't get the female to snap over and make a seal on either hose.
I have pushed pulled jiggled jammed....almost kicked
Feeling pretty stupid
Tim--BSME
   / Cant figure it out. hyd. Hose connection #2
I had a QD that had standing pressure in the implement and I could not push it onto the tractor connects. I even built the implement and it was last used in the cool weather and it was now summer. You can try to depress the center of the fitting with a brass punch or loosen the threaded connector. I had a male end and I wrapped in a clean cloth and banged it with a hard OAK stick until the oil pressure droped then I pushed it home.
Craig Clayton
   / Cant figure it out. hyd. Hose connection #3
Tim, welcome to TBN.
Seems like everyone has troubles with the Quick Disconnects from time to time.
And when you're having problems QD seems like an Oxymoron. :D
First make sure you have the pressure released from the lines. I've gone as far as loosening the connection a little then re-tighten. Also check the collar on the female that you pull back for connection. I had one that was cracked and spent over an hour playing around till I looked close and found the crack. Replace the connector and everything worked fine.
Wedge
   / Cant figure it out. hyd. Hose connection #4
I have problems with my grapple quick connects- usually the female one which connects to the male one on the loader crossbar- I have tried all the pressure relief stuff- even unhooking the other hose end at the diverter- I found that if i put a small board for extra surface area and gently apply pressure with my knee while pulling back the connector shield thing I have been successful. I have not sworn more at my tractor than attaching this one connector for my grapple hydraulic.
-Dana
   / Cant figure it out. hyd. Hose connection #5
Brain storm
Has any one tried a valve spring compressor to pull a set together?
or a battery terminal remover to depress the male ball.
41vNDkg7Z3DzlnD4E9XpoWSpDsWHUAO5J1qzYDq2Z95HIVn7Aq3-W2Rv89sOHix7JYeJXaxNnQWUj65T-M5ffc18GJHZws4x3bzXzdPxSunpbawZCIjSP5HYI5kOuZprwzmbAC0Vw7tm7vmpD7W7kfS9dLwBkLluye4TY7k
tom
   / Cant figure it out. hyd. Hose connection #6
Tim--BSME
How about a little more info, like have they ever mated before? You mentioned it was "new" so possibly the male and female are not of the same type.
   / Cant figure it out. hyd. Hose connection #7
Brain storm
tom
That would be way overkill!
   / Cant figure it out. hyd. Hose connection #9
My first thought also, Are they a mated set? assuming they are...
I don't know, maybe something like that screw in puller wouldn't be bad.
I had one on my loader that was so bound up with pressure behind the ball, a slow release from something like that would of been better than what happened to me.
Like I said mine wouldn't connect and I knew it was pressure in the female, tried playing with the loader stick, moving in all directions. Figured I had to depress the ball like I've done several times with male ends of snow plow lines, a little tap on the plow frame and a little fluid would ooze out, then would go together.
Tapped it a little, then a little more, then a pretty good whack and you guessed it I took a slippery shower:( Had a rag around it thinking what might happen, but didn't expect that amount of fluid would be released.
EDIT: I said female end but it may of been one of the male ends from the loader.
JB
   / Cant figure it out. hyd. Hose connection #10
I know but some people just won't tap the ball on the male end on machine with a rag over it (what I do) and over think it.
I never not been able to put one together unless it had a mechanical problem like the slide on the female got crunched.
tom
Case 2390 Tractor (A59814)
Case 2390 Tractor...
SUV (A59231)
SUV (A59231)
*Selling at Royal Auction Zephyrhills, FL Location* (A59230)
*Selling at Royal...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
John Deere 1790 Planter (A59814)
John Deere 1790...
