Loader Cant figure it out. hyd. Hose connection
   / Cant figure it out. hyd. Hose connection #1
CrestonNC
Creston, NC
Kubota L3800
I have a new grapple and can't figure how to connect the QD? Hydraulic hoses. I can't get the female to snap over and make a seal on either hose.
I have pushed pulled jiggled jammed....almost kicked
Feeling pretty stupid
Tim--BSME
   / Cant figure it out. hyd. Hose connection #2
I had a QD that had standing pressure in the implement and I could not push it onto the tractor connects. I even built the implement and it was last used in the cool weather and it was now summer. You can try to depress the center of the fitting with a brass punch or loosen the threaded connector. I had a male end and I wrapped in a clean cloth and banged it with a hard OAK stick until the oil pressure droped then I pushed it home.
Craig Clayton
   / Cant figure it out. hyd. Hose connection #3
Tim, welcome to TBN.
Seems like everyone has troubles with the Quick Disconnects from time to time.
And when you're having problems QD seems like an Oxymoron. :D
First make sure you have the pressure released from the lines. I've gone as far as loosening the connection a little then re-tighten. Also check the collar on the female that you pull back for connection. I had one that was cracked and spent over an hour playing around till I looked close and found the crack. Replace the connector and everything worked fine.
Wedge
   / Cant figure it out. hyd. Hose connection #4
I have problems with my grapple quick connects- usually the female one which connects to the male one on the loader crossbar- I have tried all the pressure relief stuff- even unhooking the other hose end at the diverter- I found that if i put a small board for extra surface area and gently apply pressure with my knee while pulling back the connector shield thing I have been successful. I have not sworn more at my tractor than attaching this one connector for my grapple hydraulic.
-Dana
   / Cant figure it out. hyd. Hose connection #5
Brain storm
Has any one tried a valve spring compressor to pull a set together?
or a battery terminal remover to depress the male ball.
41vNDkg7Z3DzlnD4E9XpoWSpDsWHUAO5J1qzYDq2Z95HIVn7Aq3-W2Rv89sOHix7JYeJXaxNnQWUj65T-M5ffc18GJHZws4x3bzXzdPxSunpbawZCIjSP5HYI5kOuZprwzmbAC0Vw7tm7vmpD7W7kfS9dLwBkLluye4TY7k
tom
   / Cant figure it out. hyd. Hose connection #6
Tim--BSME
How about a little more info, like have they ever mated before? You mentioned it was "new" so possibly the male and female are not of the same type.
   / Cant figure it out. hyd. Hose connection #7
Brain storm
tom
That would be way overkill!
   / Cant figure it out. hyd. Hose connection #9
My first thought also, Are they a mated set? assuming they are...
I don't know, maybe something like that screw in puller wouldn't be bad.
I had one on my loader that was so bound up with pressure behind the ball, a slow release from something like that would of been better than what happened to me.
Like I said mine wouldn't connect and I knew it was pressure in the female, tried playing with the loader stick, moving in all directions. Figured I had to depress the ball like I've done several times with male ends of snow plow lines, a little tap on the plow frame and a little fluid would ooze out, then would go together.
Tapped it a little, then a little more, then a pretty good whack and you guessed it I took a slippery shower:( Had a rag around it thinking what might happen, but didn't expect that amount of fluid would be released.
EDIT: I said female end but it may of been one of the male ends from the loader.
JB
   / Cant figure it out. hyd. Hose connection #10
I know but some people just won't tap the ball on the male end on machine with a rag over it (what I do) and over think it.
I never not been able to put one together unless it had a mechanical problem like the slide on the female got crunched.
tom
ASSET DESCRIPTIONS & CONDITION (A57880)
ASSET DESCRIPTIONS...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2010 GMC Acadia SL SUV (A56859)
2010 GMC Acadia SL...
2006 Ford Taurus Sedan (A55853)
2006 Ford Taurus...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
