Oil & Fuel Can't Believe This Happened
/ Can't Believe This Happened #41
Called the Sheriff and reported a vandalism to my tractor. The plug had marks on it like someone had used a crescent wrench or pliers. I also notified KTAC insurance and submitted a claim. The dealer came out with a trailer and winch and we got it loaded up and to his shop.
I'll keep you informed. Thanks for all the comments. Hopefully we can all use this as a learning experience.
Hope it all turns out OK for 'ya!!
/ Can't Believe This Happened #42
That could have happened to any of us. If the nut were loose to begin with, I think Rockin would have seen some drips of oil on the cement or ground before getting on the tractor. I usually take a quick look around before starting something, like most of us all do. That's an odd one. Let us know what happens, Rockin.
/ Can't Believe This Happened #43
Wow, this guy could have major trouble with his, new to him, tractor and he gets a lecture like that. He has more control than I. I would have told you to go **** yourself.
Like i give a F/
/ Can't Believe This Happened #44
Wow, how depressing. I check my fluids about every other use, but my usage tends to be 3 - 4 hours at a time at most. Guess I have to go check it right now!!
/ Can't Believe This Happened #45
Wow talk about bad luck... Vandalism or accident, either way I feel for you. I never really thought about no low oil shutdown on our tractor....
Our Cubcadet lawn mower has something called "Oil Sentry" that I believe is some type of low oil shutdown, but I'm not sure what our Kioti CK20s has. Probably and idiot light which would do nothing for a total loss due to a drain plug. All a light is good for is a slow leak and then it's still iffy as to preventing damage. Really what good is a light in this situation, when your focused on maneuvering the tractor and not staring at the dash? Might as well call it a "your engine is seized light!" It could light up a dollar sign just to rub it in :(
We just got our CK20s and the dealer put the darn 3pt arms with the bolt facing outwards towards the tires instead of the head. It rubbed a little but didn't seem to do much to the tire; it could have over time though. Really makes me want to double check any other work they do on the tractor! Including the drain plugs.
Well, this has been a learning experience that's for sure; heck a lawn mower is throw away compared to the cost of fixing a tractor. :eek:
Anyway I hope you have a good outcome and resolve things without a huge bill on your end. I second all the calls to check our own drain plugs... Makes me want to re-torque everything on the tractor and be more diligent with checking fluids and well everything else.
Later, Glen
/ Can't Believe This Happened #46
If, ask Rockin says he does, he checked his oil before using the tractor and the plug and had been loose the entire time then it would have been low on oil and he would have noticed it. Oil would have leaked out around the threads. This is the work of someone with less than honorable intentions. Sad that to someone would think this was fun to do.
What's really needed is a low oil pressure switch. Something that'll shut the engine down before any damage is done.
/ Can't Believe This Happened #47
I agree,if I had a bolt going into an aluminum anything I would use the torque wrench.Way to easy to strip something like that out.
Brian
/ Can't Believe This Happened #48
Yes, That's what the "Oil Sentry" on my old CubCadet lawn tractor with a Kohler engine does (or is supposed to do; I've never actually tried it). It will kill the engine if the oil level is below a certain point. You'd think a real tractor would have such a thing as well. Maybe there is a good reason but you would think they'd be able to engineer something besides a silly light that just tells you it's too late! :thumbdown:
With all the safety shutdown garbage on my old Cub I have fun trying to figure out why when it wont start or stay running. It's nice when all the switches and sensors are working but it's no fun trying to figure it out when one doesn't. :laughing:
Maybe we just need another government agency to check our drain plugs and oil level and make us buy fuel cans that don't let the fuel out! They can call it The Federal Dept of Lubed Rear Ends... :drink: It could be a part of the EPA (aka the Employment Prevention Agency)
Anyways enough jokin, I'll say a prayer for a good outcome for you; and if you DO think it was vandals please check everything else you can think of as well. It'd be odd if that was the only bad thing they did. That's way beyond a prank!
Oh, You may want to look into some type of simple security warning system. Like a couple of motion sensor lights where you store it; or we have a couple of those driveway sensors from harbor freight that work well if you're house is not too far away. We have several out in our yard and if something walks/moves in front of it, it sets off a doorbell like receiver in the house. They're like $15 on sale at Harbor Freight and use a 9v on the transmitter and a couple C batteries in the receiver. Get a couple on the same channel and it will set off the same receiver.
They do have false alarms here and there (wandering deer and such) but it's worth it to know when someone pulls into the drive or is near the barns. Cheap warning if you don't want or have a dog to change peoples minds. At least you'll know they're there! I'm sure they make better ones too if you're more than 100' or whatever the range is.
Again, Good Luck
/ Can't Believe This Happened #49
Not to likely a piece of mobile equipment has a shut down. Many years ago a farm equipment company put Murphy switches on their machinery. Combine stopped on railroad tracks and got hit. Driver survived to say what happened and to sue. Payout was enormous. Word got around quickly and Murphy switches have been relegated to stationary power units. At my last company standard was low oil pressure = light plus warning horn. Standard manual statement to stop as quickly as you could safely do so. Lots of lower priced Cat equipment goes as rental first with used sales to end users (like my mini-excavator). Warnings of different importance levels for hydro charge pressure, hydraulic oil temperature, hydraulic filter plugging, fuel filter plugging, that I would like on my tractor but I suppose they want to save money. Rentals get abused so lots of brought lights and audible warnings with few gauges. Rental drivers don't often know what the gauge reading is supposed to be but unless they are deaf, they understand a 100 dBA alarm even with ear protection.
/ Can't Believe This Happened #50
I don't see how checking fluids before a start can really help. Its a feel good thing for sure, especially if you are burning the oil. My JD doesn't leak anything until the plug drops out. I'd expect an overheat arm buzzer to maybe sound off just before it locked up.
If it just got tight, I'd put some fogging oil in there, say a prayer and roll it down an incline after I put the plug back in, added some oil and covered the top end with it, too. If it got really hot, wouldn't the hydraulic oil be cooked, too?
If it was tampered with, I'd look for problems on other machines, too.
/ Can't Believe This Happened #51
Lesson learned. Always check your fluids before starting out for the day.
Standard practice for any competent equipment operator.
Hope you can get out of it without costing you too much.
Lets say he DID check his oil before he started, most likely it would have read ok. He clearly stated he had been working the tractor 3-4 hours prior to it shutting down. When it did shut down, he noticed the oil trail on the ground behind him. Since you are a competent equipment operator, you should know upon removing a drain plug, it will only take approx. 10 seconds or less to drain enough oil before something catastrophic may happen.
This has NOTHING to do with checking fluids before beginning work. And if you say you climb under your tractor and check the torque on drain plugs every time you begin a job, your full of $h--.
/ Can't Believe This Happened #52
**** no i dont torque or check drain plugs every time..
But when a new piece of equipment comes into my possession i sure do. You have no idea what the previous owner or last person who worked on it did. I strongly doubt it was vandalism in this case. IMHO the plug was loose, and likely loose and slow leaking for many hours, likely before the OP purchased it. Then one day it just fell out. An inspection when it came into his possession would have picked it up.
If it was vandalism, well that sucks. Not much you can do if your sabotaged. Removing drain plugs isnt typical of vandals in my experience. More than once I was called to repair equipment that had batteries taken, windows smashed, radio's removed and/or tires flattened, but that's the extent of it. I once heard of a loader that had several qts of oil siphoned out of it, I can only guess somebody atv'ing or something had to do a oil change after getting swamped, but that was picked up by the operators check at the start of shift.
/ Can't Believe This Happened #53
I can agree with this.
/ Can't Believe This Happened #54
I do all of my own maintenance but the couple times I let a dealer touch it I sure learned to check their "torque" afterwards. They had the pan nut so tight I could barely get it loose. Had the shop gorilla put on the hydraulic filter so tight I had to destroy it to remove it. And not consistant either--others left my oil pan nut on the car loose and it dripped oil. No more ever--i do all my own work now and plan to as long as possible.
The OP's issue is one in a million and he clearly did all that was required and more than most of us would. He checked his oil at the start of day. Who was to know some deviants loosened the pan nut? Let's hope it's insured. As well, if tampered with, this type of punk is not smart enough to shut up and will likely brag to someone. A sheriff with his ears open will eventually get a lead--from the perp himself. Good luck on this and push the insurance issue. At least it's only money and can be fixed. No family was harmed.
/ Can't Believe This Happened #55
From what I have read in this thread I would guess that this tractor may actually have a low pressure shut down circuit and should have no engine damage. The reason I say that is that I have seen a few engines that had no oil plug (no oil) that lasted way longer than an instant lockup after loosing oil.
OP said he saw a trail of oil which means he had just lost all the oil. A dealership where I worked in the early '90's had to destroy and scrap a Nissan van. The techs drained all of the oil and started it. It ran a total of more than 12 hours before locking up. At 10 hours they drained the coolant which sped up the process.
At another dealer we had a "tech" forget to put the drain plug back in during an oil change. The customer went 4 miles in town and then 7 miles on a 70mph interstate before the noise caused her to stop. We gave her a new engine then tore down her old one and found no damage, although we did replace rings and bearings. That engine went into another car and gave no problems.
Not long ago I saw the same situation again but this owner was called and stopped a few miles away. Plug was installed and engine filled with oil and he has had no problem since.
I know this is a tractor at working rpm but I wouldn't expect any different results... especially since diesel oils contain MUCH higher levels of zinc and phosphorus which are the main additives that provide metal to metal lubrication.
Hopefully the OP got lucky.
/ Can't Believe This Happened #56
About 15 years ago, a local quick-lube left the oil plug loose on my Grandmothers '70's Nova with a 305. A couple miles away it came out, and dumped all the oil. It got towed back to the quick-lube, another plug put in, with fresh oil and filter. Lasted her a few more years. She sold it, still running fine.
Hope it is same for OP...
/ Can't Believe This Happened #57
OP stated that he was brush hogging in "tall grass". That being said, I can almmost gaurantee that he had the engine running at full throttle under a load. Under these conditions, I don't see how that the engine couldn't be anything but JUNK.
Kubota offers a NEW complete engine through wholegoods. These are complete drop ins whit just having to swap out the accessories(starter, alt, fan, clutch and maybe the flywheel) to the new engine and come with a 1 year warranty. Considering this is probably a catostrophic loss, the crank, rods, main bearing carriers, camshaft, and block will all need to be replaced. Add to that the labor to disassemble and reassemble the engine, you are further ahead to go with the complete engine. The only labor involved would be just to R and R the engine.
Current list price on a V2403E3G engine is $5408.00. PLUS freight and installation.
/ Can't Believe This Happened #58
Well, now, that's interesting, and has got my mind working. My tractor has a low oil pressure light. With a little creativity and some relays, I bet you could easily wire that to blow the horn when it's on as well. Only problem is, the light comes on when the key is turned, but the engine is not running, and that would be annoying. Is there some lead that only has current on it when the tractor is running, and not just when the key is turned? That way, you could wire it up so that if the oil pressure light is on and the engine is running, the horn blows. My tractor is a diesel, so in theory it doesn't need electrics to keep running. On the other hand, something shuts down the engine when I turn off the key. What is that?
/ Can't Believe This Happened #59
You could just add in a timer circuit that overrides the low pressure switch when the ignition switch is first turned on. You could set it for 1 minute. So each time you went to start your tractor you would have 1 minute to start it (more than enough time in winter) or it would sound the alarm. You could even tie it to your fuel shut off so it kills your engine. But the real question is how many people have this problem? Is it really worth the effort for a 1 in 10 million problem?
/ Can't Believe This Happened #60
I wouldn't tie it to a fuel shutoff, for the reason previously described: an unexpected shutdown can be catastrophic in a moving vehicle. There are times when I'd rather move the tractor than save the engine.
How many people have this problem? If you mean the drain plug falling out, very few. But if you mean running an engine on low oil? Well, that's why they put a low oil pressure light on the dash, right? I mean, **** happens, right?
EDIT TO ADD: And, just out of curiosity, I'd still like to know if there is something on the tractor that only has voltage when the engine is actually running, that you could run a relay off of.
