Canning question
   / Canning question #1
elalexander
Western Maryland
1982 Bolens/Iseki TS 1910 f (G194)
We haven't canned for about six years but will most likely start back this year. My question is that since we canned last we have bought a ceramic top stove. Someone was telling my wife she can't can on a smooth, glass top stove. The owners manual just says use flat bottom cookware, and does not mention canning at all.
We dont want the stove top to break and have a hot water bath fall and scold someone. Has anybody heard of this, and or know what kind of canning supplies I may need. Our old canners do not have a smooth bottom but rather several rings.
   / Canning question #2
Yeah,not sure if its the weight or something else,but we bought a new stove a year or so ago and didn't get one of those cause we can[can't remember the exact reason].
   / Canning question #3
We do a lot of canning but not on that type of stove...i did a search on the Web and there was many links that may help you.
This is what i typed in to search the Web.
"canning on a flat top stove"
   / Canning question #4
Our recommendation, therefore, is to contact the manufacturer of your smooth cooktop before making your decision to can (or not) on it. They are the recommended source of this information and may also have up-to-date alternatives or suggestions for equipment that you can use. We also caution that you might have to be sure they understand how large your boiling water or pressure canner is, how long it must be heated at high heat, how long the hot canner may stay on the burner until it cools after the process time, and that the canner is made from aluminum (if it is).
August 25, 2006
National Center for Home Food Preservation
This sounded like reasonable advice:D
regards
   / Canning question #5
The manual for our KitchenAid electric ceramic range has specific instructions for "Home Canning" which does say to use only flat bottomed canners, it should not extend more than 1" outside the cooking area, and when canning for long periods, to alternate the use of surface cooking areas.
It also says on coil element models, "installation of a Canning Unit Kit is recommended. If not installed, the life of the coil element will be shortened." I have no idea what that "Canning Unit Kit" consists of.
   / Canning question
Thanks for the advice. My wife makes a hugh 24 quart pot of veggie soup to freeze and this sits on the stove most of the day. I'll have to call Frigidaire tomorrow.
It makes you wonder how many people are using these things to can with and what type of failure, if any, people are having.
Bird, what type of canning baths, pressure cookers do you use? Are there any designed for flat top stoves? From what I have seen it seems the heat for long periods are well as weight are the two reasons given for not using these to can on.
   / Canning question #7
Eric, all we have anymore is just a small aluminum pressure cooker, and haven't done any canning recently. If we were going to use a bigger one, I'd use our LPG burner outside that I bought for frying fish and making blackened fish.
   / Canning question #8
Probably two reasons not many complants as to canning on these type stoves,one would be,most people who do can don't go for these newbie things,two would be probably only one out of 5,000 homes even can food anymores.
My wife cans probably 2-300 jars a year,greenbeans,beets,pickels,tomatoes and tomato juice,apple sauce,jellys,blackberries,etc,etc.
   / Canning question
Thanks Bird. My neighbor is going to do the LP /camping burner type set up to can on his carport. Seems like a lot of hassle to an already busy time of year.................canning season. Greenmule I remember my Mother in law's dinner with all of those canned goods from their garden. I think my two favorites had to be the corn and Sauerkraut. We had a nice size garden when our kids were at home and did some canning and freezing but not 2 or 3 hundred. Those of us lucky enough to have girls that do,did or were raised with canning and growing vegtables and fruits are lucky. Like you said only 1 in several hundred of thousand people can anymore. Sad in a way, especially when there is a news report about something in lettuce, tomatos, peppers or most recently peanuts making people sick. It sure is nice to have strawberry shortcake in December with berries you picked and froze in June.:D
   / Canning question #10
Yep, Eric, before we had to move back to town 6 years ago, from what we raised ourselves, we "canned" blackberry and plum jelly, green beans, new potatoes, blackeyed peas, beets (both pickled and not pickled), and cucumber and okra pickles. We both canned and froze yellow squash and zuccini, and we froze corn, okra, bell peppers, and pecans. Canned corn is good, of course, but we both prefer it either fresh or frozen. And my wife and a neighbor worked together making and canning salsa, but I never had anything to do with that.
Of course at that time, we had a conventional electric range; not a smooth top.
And years ago, the biggest canning job was when we, or my parents, visited Alaska and brought back salmon to can. But we haven't done that since 1990.
2025 K1912 UNUSED Metal Livestock Shed (A50860)
2025 K1912 UNUSED...
2024 iDrive TDS-2010H Pro Jack M2 Electric Trailer Jack System (A48081)
2024 iDrive...
UNUSED Plastic Mesh Safety Fencing Roll (A50860)
UNUSED Plastic...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A48081)
2008 Ford F-750...
