Can you help me decript this serial number?
   / Can you help me decript this serial number? #1
woodenBadger
Brandon Twp. MI
I'm trying to finalize the loan paperwork for a tractor I'm interested in, and when I called the guy to get the serial number, he rattled off a number like I had never heard before. He's an old man, and no matter what I asked him, I couldn't get a clear answer from him as to what was what.
I need the year and serial number. It's a John Deere 955, and he did tell me that some of the numbers were from the loader (he just didn't seem to know which). Can anyone help me make heads or tails of this?
955 LM00714083731ND4PJ-CH3048D025074
thanks
Doug
   / Can you help me decript this serial number? #2
As near as I can tell, that serial number was used on an early model IND4PJ nucular bomb model year 1946. It was originally designed to be dropped on Germany, but was lost for the last 59 years in the Nevada desert. Nice find!
Well, I'm in Michigan, so I guess it was WAY off course.
   / Can you help me decript this serial number? #5
If you have a Deere dealer to work with, then they can look up that number and give you the particulars of when it was sold, and any follow-up that is logged into their computers.
I got a good chuckle out of the 'bomb' explanation /forums/images/graemlins/grin.gif
ok, so apparently none of these numbers are the serial. One is the loader, and the other is the engine.
Anyone know where the serial number for a 955 is located?
   / Can you help me decript this serial number? #7
The tractor serial number should be at the rear of the tractor below the pto and above the drawbar.
   / Can you help me decript this serial number? #8
serial number should be located on a plate just below the rear PTO shaft (not the best place!)
You are looking for .......
955 COMPACT UTILITY TRACTOR
JOHN DEERE 955 TRACTOR WITH BASIC HYDRAULICS
1990 MODEL YEAR (SERIAL NO. M00955C010001-100000)
1991 MODEL YEAR (SERIAL NO. M00955C100001-100699)
1992 MODEL YEAR (SERIAL NO. LV0955C100700-129999)
1993 MODEL YEAR (SERIAL NO. LV0955C130000-175000)
1994 MODEL YEAR (SERIAL NO. LV0955C175001-175129)
1995 MODEL YEAR (SERIAL NO. LV0955C175130-179999)
JOHN DEERE 955 TRACTOR WITH SCV
1990 MODEL YEAR (SERIAL NO. M00955D015001-100000)
1991 MODEL YEAR (SERIAL NO. M00955D100001-105699)
1992 MODEL YEAR (SERIAL NO. LV0955D105700-139999)
1993 MODEL YEAR (SERIAL NO. LV0955D140000-180000)
1994 MODEL YEAR (SERIAL NO. LV0955D180001-182278)
1995 MODEL YEAR (SERIAL NO. LV0955D182279-189999)
1996 MODEL YEAR (SERIAL NO. 1V0955E190000-199999)
1997 MODEL YEAR (SERIAL NO. 1V0955E200000- )
Thanks for the tips. I drove over there last night to check it out myself again, and all that's under the pto is two empty rivet holes.
I did find some numbers stamped into the frame on the rear, left of the PTO, 6 digits, starting with a 2, but hard to read. Also, the plate on the oil pump in the back has some overspray on it, as if the whole rear had been replaced, repainted, and perhaps the serial not transfered?
Other then that suspicious bit, everything looks great, and seems like a deal I don't want to pass up, but something about that tag seems fishy. The old man is a retired guy that has a bunch of heavy macinery and tractors on a farm lot. seems like a decent operation, but what do I know? He claims that the owner bought it and used it for a couple years , then died, and he's selling it for the wife.
Should I pass? or can this stuff happen? I want the tractor, but not if it's going to cause me problems with maintenance and possible resale.
Here's a picture of that stamped number
   / Can you help me decript this serial number? #11
Shouldn't the engine have a serial number as well? I wonder if you can get that and a Deere dealer can cross-reference it back to the tractor?
thanks, I do have a valid engine serial and model number, along with a serial number from the loader. I have someone at a JD dealership trying to help me out.
Just hoping to get the general feel from some people a bit more experienced then me.
BTW, the engine serial is CH3048D025074 and the loader SN is M0070AX140830, just in case there's anyone else looking that might be able to cross check the numbers.
thanks
doug
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2012 International 4300 Reefer Truck (A61306)
2012 International...
BLUE DIAMOND HYD 16" SERIES 2 COLD PLANER (A60429)
BLUE DIAMOND HYD...
2353 (A60432)
2353 (A60432)
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
2003 Big Tex 10PI...
