can someone explain the difference.....
/ can someone explain the difference..... #1
MeadowStoneFarm
CONENCTICUT
...between Yanmar series, like the YM/F/FX/YMG. How is a newer FX different than an older YM?
also i am in the market for one of these tractors. i'm located in ct, haven't had much luck finding dealers aorund. anyone know of a good one near me? all i've found is a place called zephyr knoll farm in ny.
/ can someone explain the difference..... #2
I could be wrong but think the F and FX are the same except for the power shift on the FX.
is the power shift similar to a shuttleshift? i have a ford 555 with a shuttle shift and i'm not impressed with it. anyone know if it puts more were and tear onthe clutch?
/ can someone explain the difference..... #4
power shift is like an automatic transmission in a car .I don't know if it's the same as shuttle shift. You can get power shift on a ym.
/ can someone explain the difference..... #5
Power shifts have fluid clutches as does power shuttles. A fluid clutch takes forever to wear out. They will out last many dry clutches. The difference between a power shift and power shuttle is that with a PShift you can change directions or shift gears without clutching. A PShuttle only changes directions without the clutch. With a standard or regular shuttle you have to use the clutch for everything and it is a dry clutch.
/ can someone explain the difference..... #6
To my understanding, YM's are grey market, FX's are American sold.. May be wrong, but thats the way I understand it.
/ can someone explain the difference..... #8
That is not correct. All are Gray except the old 3 number models. Like ym240. F are from late 80s early 90's. Most have more of a step through floor. I prefer the oldies but I would not hesitate on an f or fx. I don't really know what the x stands for. It may mean powershift? Late 90's 2000's are k or ke like ke200 etc... Not too many of them here but some...
I am not an expert like the dealers on this forum are...
/ can someone explain the difference..... #9
Jerry is correct, I should have explained a little more . On power shift you can change gears & go to reverse without the use of the clutch.I have power shift on my 3110D.
/ can someone explain the difference..... #10
Re: can someone explain the difference..... *DELETED*
Post deleted by pruntyc
/ can someone explain the difference..... #11
thanks ,I missed that. Happens to me sometimes when I try too type fast.
/ can someone explain the difference..... #12
Great,
Thanks for the correction, /forums/images/graemlins/blush.gif.. Thats how it was explained to me, sorry for the missinformation guys...
CAT 12G 14' Moldboard (A68134)
CAT 12G 14'...
2005 John Deere 225CLE Hydraulic Excavator (A66734)
2005 John Deere...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
213088 (A64276)
213088 (A64276)
2005 Infiniti FX35 AWD SUV (A66738)
2005 Infiniti FX35...
