Snow Equipment Owning/Operating Can snow pushers scrap down
   / Can snow pushers scrap down #2
My gravel has not frozen yet, and I can scrape up gravel with mine if I am not careful. But not nearly as much as when using the blade on the plow truck.
If you need to get down to gravel, and the pusher will not get to where you want, use a back blade to scrape the last inch or so. That was my plan but so far the pusher has done a great job. Only used it twice. Got rid of both my inverted blower and contractor grade plow. Sold them for $7600 and the $1700 pusher is far better so far.
One last option. There is a back drag option for the pusher (about $800) that would likely scrape down, but you would be driving in reverse.
   / Can snow pushers scrap down #3
I do a few driveways that are steep and need to be scrapped down to gravel. Can you scrape down using a pusher?
Can it do it as well as a bucket?
I can’t see why not. They aren’t structurally as strong as a medium duty loader bucket, but pushers can withstand some down pressure.
I guess it all depends on your definition of “down pressure” like is it light or heavy down pressure.
   / Can snow pushers scrap down #4
Does your pusher have skid shoes that keep the scraper blade from ground contact? Reason for asking is that I have seen some at dealership where scraper blade was not in contact with ground. I did not look close enough to see if skids were adjustable though.
Thanks. Everybody seems to like their snow pusher.
I guess I should of explained that I am seriously looking at buying one. I don’t have one yet. I am looking at the HLA snow pusher and they have adjustable shoes. I could set them low and likely scrape close enought to the gravel.
Thanks for your comment.
   / Can snow pushers scrap down #7
My buddy who recommend a pusher to me has the HLA and he really likes it. He got the pull back option and can get close to building with it.
I ended up with a Land Pride as it was less money.
   / Can snow pushers scrap down #8
They are used in parking lots and work for that. Trip edge and skid shoes, set the shoes right and it should scrape. Pull back option is a must in my opinion.
I don't think you can get the "front wheels in the air and aggressive angle" with a pusher.
Yamaha Kodiak ATV (A59814)
Yamaha Kodiak ATV...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2011 John Deere 7330 (A59814)
2011 John Deere...
