Can One Ship High Power Magnets?
   / Can One Ship High Power Magnets? #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I was about to order four rubber coated high power magnets 43mm, from China? They are to hold a light assembly onto my Cushman Mower Canopy.
I wonder if I would ever get them, or if they would stick to a bin or processing equipment on route. I did ask the vendor but I suspect, they won't understand what I am talking about.
It's interesting, because holding sidearms in place for ready use, seems to be a popular application for this type of magnet.
   / Can One Ship High Power Magnets? #2
Unless they're astoundingly powerful (probably requiring liquid nitrogen for cooling and lots of electricity) - like that used for an MRI (Magnetic Resonance Imaging) - my guess is that a smallish magnet, even very strong, in the middle of a large box will be fine and pretty much non-responsive.
Magnetic fields fall off with the square of distance, and you're intending to use them in direct contact (very small distance) which is where they're "very strong". From 3 inches away, you'll be able to feel a light tug. My guess is as strong as that is, you wouldn't be able to feel much of a pull from the magnet with it a foot away from a ferromagnetic metal; shipping the magnet in the middle of a box to provide some distance would be sufficient to keep it from getting "stuck" to anything else.
Most of the stuff I get from China are shipped in E-Packets, (strong padded envelopes). That wouldn't do well with these rare earth magnets.
Stupid thing is, shipping is FREE from China, but there is a Canadian supplier that's cheaper, but the shipping is outrageous, via Canada Post, which would be delivering the Chinese magnets to my mailbox anyway.
   / Can One Ship High Power Magnets? #4
I just yesterday got my third shipment of neodymium's from magnets4sale.
I usually get a big one (450 pull) about a dozen 120 lb'ers and some miscellaneous.
Never a problem in shipping. They shipped with about a 4" thick roll of bubble plastic.
Only "problem" I've had is in deciding which ones to get.
Interesting. Thanks. I know being in the security business, many magnets have simply disappeared. Sometimes you find them much later, stuck to a hammer or other tool.
The E-Bay listing warns "will pinch finger badly"
   / Can One Ship High Power Magnets? #6
A friend showed me he would drop one through a 36" long section of 3/4" copper pipe. It would slowly float down to the other end, he explained why, something about creating such a high magnetic field.
   / Can One Ship High Power Magnets? #7
That phenomenon is one of the most interesting things I have seen lately.
   / Can One Ship High Power Magnets? #8
I recall a science project a friend of mine in High School did. Had a mild steel rod about 10 inches long with a small coil at the bottom (20 gauge copper about 200 wraps?). When energized with ac current a small aluminum ring would rise up the rod. Alternating magnetic field would induce a current in the ring creating it's own opposite magnetic field.
   / Can One Ship High Power Magnets? #9
Strong permanent magnets should have a removable shunt (steel plate) to confine the magnetic field during shipping. For example, a horseshoe magnet would have a shunt between the poles.
Good luck
   / Can One Ship High Power Magnets? #10
Good luck
Is that something like a new regulation?
I've gotten 3 of these 400lb+ pull magnets over the last 4 years and this last one came with a steel plate the size of the magnet.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A55788)
2015 Chevrolet...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
