Can One Ship High Power Magnets?
   / Can One Ship High Power Magnets? #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I was about to order four rubber coated high power magnets 43mm, from China? They are to hold a light assembly onto my Cushman Mower Canopy.
I wonder if I would ever get them, or if they would stick to a bin or processing equipment on route. I did ask the vendor but I suspect, they won't understand what I am talking about.
It's interesting, because holding sidearms in place for ready use, seems to be a popular application for this type of magnet.
   / Can One Ship High Power Magnets? #2
Unless they're astoundingly powerful (probably requiring liquid nitrogen for cooling and lots of electricity) - like that used for an MRI (Magnetic Resonance Imaging) - my guess is that a smallish magnet, even very strong, in the middle of a large box will be fine and pretty much non-responsive.
Magnetic fields fall off with the square of distance, and you're intending to use them in direct contact (very small distance) which is where they're "very strong". From 3 inches away, you'll be able to feel a light tug. My guess is as strong as that is, you wouldn't be able to feel much of a pull from the magnet with it a foot away from a ferromagnetic metal; shipping the magnet in the middle of a box to provide some distance would be sufficient to keep it from getting "stuck" to anything else.
Most of the stuff I get from China are shipped in E-Packets, (strong padded envelopes). That wouldn't do well with these rare earth magnets.
Stupid thing is, shipping is FREE from China, but there is a Canadian supplier that's cheaper, but the shipping is outrageous, via Canada Post, which would be delivering the Chinese magnets to my mailbox anyway.
   / Can One Ship High Power Magnets? #4
I just yesterday got my third shipment of neodymium's from magnets4sale.
I usually get a big one (450 pull) about a dozen 120 lb'ers and some miscellaneous.
Never a problem in shipping. They shipped with about a 4" thick roll of bubble plastic.
Only "problem" I've had is in deciding which ones to get.
Interesting. Thanks. I know being in the security business, many magnets have simply disappeared. Sometimes you find them much later, stuck to a hammer or other tool.
The E-Bay listing warns "will pinch finger badly"
   / Can One Ship High Power Magnets? #6
A friend showed me he would drop one through a 36" long section of 3/4" copper pipe. It would slowly float down to the other end, he explained why, something about creating such a high magnetic field.
   / Can One Ship High Power Magnets? #7
That phenomenon is one of the most interesting things I have seen lately.
   / Can One Ship High Power Magnets? #8
I recall a science project a friend of mine in High School did. Had a mild steel rod about 10 inches long with a small coil at the bottom (20 gauge copper about 200 wraps?). When energized with ac current a small aluminum ring would rise up the rod. Alternating magnetic field would induce a current in the ring creating it's own opposite magnetic field.
   / Can One Ship High Power Magnets? #9
Strong permanent magnets should have a removable shunt (steel plate) to confine the magnetic field during shipping. For example, a horseshoe magnet would have a shunt between the poles.
Good luck
   / Can One Ship High Power Magnets? #10
Good luck
Is that something like a new regulation?
I've gotten 3 of these 400lb+ pull magnets over the last 4 years and this last one came with a steel plate the size of the magnet.
2015 TAKEUCHI TL10 SKID STEER (A52705)
2015 TAKEUCHI TL10...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2007 Ford F-150 Crew Cab Pickup Truck (A55788)
2007 Ford F-150...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
