Can I use spring harrow to break up plowed ground
   / Can I use spring harrow to break up plowed ground #1
Ndonavan
Mahindra 4550 4wd
Please help my disc that I ordered never came thru and I plowed the field I wanted to plant already I have old spring harrow that is in good shape could I use that or what other options could I use
   / Can I use spring harrow to break up plowed ground #2
Rototiller,much more efficient that a disc on smaller tractors.IMHO
Must be warm where you are if you are planting.
  • Good Post
Reactions: JJT
   / Can I use spring harrow to break up plowed ground #3
A Landscape Rake or Rear/Angle blade will serve to reduce plow furrows. Two grading implements, which move dirt along the face of the implement, filling in, when used on an angle.
A Box Blade would require two or three times longer but would serve. A dirt transport and smoothing implement.
Spring Harrows move only minuscule amounts of dirt with each pass.
   / Can I use spring harrow to break up plowed ground #4
Welcome to TBN.
Can you rent or borrow disc?,harrow do job lot of work.
AS other gentlemen said. (y)
   / Can I use spring harrow to break up plowed ground #5
What type of field was plowed?
If previous cultivated land the spring toothed harrow should work. A diamond harrow would be ideal.
If turned over sod a disc is in order.
Yea the field hasn’t been planted in twenty years
UNUSED RAYTREE RMRB72 72" HYD POWER RAKE BUCKET (A57193)
UNUSED RAYTREE...
2020 HAMM HD+120I VV-HE SMOOTH DOUBLE DRUM ROLLER (A52707)
2020 HAMM HD+120I...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2017 BMW 540i Sedan (A55853)
2017 BMW 540i...
UNUSED FUTURE FT850 VIBRATORY ROAD ROLLER (A57192)
UNUSED FUTURE...
UNUSED FUTURE 3' X 10" GALVALUME METAL SHEETS (A57193)
UNUSED FUTURE 3' X...
