Can I use spring harrow to break up plowed ground
   / Can I use spring harrow to break up plowed ground #1
Ndonavan
Mahindra 4550 4wd
Please help my disc that I ordered never came thru and I plowed the field I wanted to plant already I have old spring harrow that is in good shape could I use that or what other options could I use
   / Can I use spring harrow to break up plowed ground #2
Rototiller,much more efficient that a disc on smaller tractors.IMHO
Must be warm where you are if you are planting.
  • Good Post
Reactions: JJT
   / Can I use spring harrow to break up plowed ground #3
A Landscape Rake or Rear/Angle blade will serve to reduce plow furrows. Two grading implements, which move dirt along the face of the implement, filling in, when used on an angle.
A Box Blade would require two or three times longer but would serve. A dirt transport and smoothing implement.
Spring Harrows move only minuscule amounts of dirt with each pass.
   / Can I use spring harrow to break up plowed ground #4
Welcome to TBN.
Can you rent or borrow disc?,harrow do job lot of work.
AS other gentlemen said. (y)
   / Can I use spring harrow to break up plowed ground #5
What type of field was plowed?
If previous cultivated land the spring toothed harrow should work. A diamond harrow would be ideal.
If turned over sod a disc is in order.
Yea the field hasn’t been planted in twenty years
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2013 Freightliner M2 106 Altec AA755 55ft Bucket Truck (A55852)
2013 Freightliner...
Inclosed Trailer (A56857)
Inclosed Trailer...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
MAX MANUFACTURING 28PT500 ORCHARD SPRAYER (A57192)
MAX MANUFACTURING...
202481 (A54757)
202481 (A54757)
