Can I use spring harrow to break up plowed ground
   / Can I use spring harrow to break up plowed ground #1
Ndonavan
Mahindra 4550 4wd
Please help my disc that I ordered never came thru and I plowed the field I wanted to plant already I have old spring harrow that is in good shape could I use that or what other options could I use
   / Can I use spring harrow to break up plowed ground #2
Rototiller,much more efficient that a disc on smaller tractors.IMHO
Must be warm where you are if you are planting.
  • Good Post
Reactions: JJT
   / Can I use spring harrow to break up plowed ground #3
A Landscape Rake or Rear/Angle blade will serve to reduce plow furrows. Two grading implements, which move dirt along the face of the implement, filling in, when used on an angle.
A Box Blade would require two or three times longer but would serve. A dirt transport and smoothing implement.
Spring Harrows move only minuscule amounts of dirt with each pass.
   / Can I use spring harrow to break up plowed ground #4
Welcome to TBN.
Can you rent or borrow disc?,harrow do job lot of work.
AS other gentlemen said. (y)
   / Can I use spring harrow to break up plowed ground #5
What type of field was plowed?
If previous cultivated land the spring toothed harrow should work. A diamond harrow would be ideal.
If turned over sod a disc is in order.
Yea the field hasn’t been planted in twenty years
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
WACKER NUESON PUMP PT2A (A52472)
WACKER NUESON PUMP...
2025 25ft 1 Gauge 800 Amp Booster Cables (A50323)
2025 25ft 1 Gauge...
