Can I use angle iron this way
   / Can I use angle iron this way #1
shadetree
This will be category 0 3 point lightweight forks, can the angle iron be turned this way or would a L shape be better? Forks ~34 inches long Frame 20 inches wide.
Thanks, This is really going to be for light weight stuff. Will be hooked to the 140 3pt that is on the front of a 318 so loads will be less than 300 pounds. I already have some angle iron just wondered if kinda turning them upside down would be alright?
   / Can I use angle iron this way #4
They are a lot weaker in that orientation. However, it's possible they will still be OK. I'd suggest calculating the loads/deflection. You don't want to guess at this stuff -- would be a shame to ruin the forks after doing all the work to fab them.
I'm sure it is 3/16 inch and believe it is 1 1/2 x 1 1/2 but it might be 2 x 2.
   / Can I use angle iron this way #7
With 3/16 inch you'll be pushing it lifting 300 lbs. It may work for a while but will probably bend. I made a set pf 3 pt. forks using 1.5 x 4 x 1/4" thick channel and have bent them. I straightened them out and welded reinforcing plate steel on the bottom of them but rarely use them since I bought a set of QASS forks.
If possible, clamp one of your pieces of angle in a vise then 34" away from the vise put your full weight on the angle to see if it flexes.
Just my opinion but I would not feel safe lifting something using the angle you have.
   / Can I use angle iron this way #8
Do it right and it will last a lifetime. 3/16 will be light.
   / Can I use angle iron this way #9
If you have plenty of this angle iron, use 4 pieces. Lap 2 together forming a C channel then stich weld them together.
Even though you may not bend the single 3/16 with weight you plan to lift, they could bend digging into ground while sliding under the load.
   / Can I use angle iron this way #10
Angle's not going to be a good choice. Find some used forks. I got mine for $99/pr and they're hardly used.
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
2013 HINO 388 (A50854)
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
