Can I use angle iron this way
   / Can I use angle iron this way #21
I'd suggest going with C channel - I made mine out of C channel and even hanging weight off the tips I haven't bent them yet. My loader doesn't have a massive lift capacity (but more than a 318!) so you'd be fine with it and the weight difference between the c channel and angle should be minimal.
E.
   / Can I use angle iron this way #22
E.
G
That' s what I would think too. You will find that stuff fairly inexpensive at a steel fab outfit. The stuff I got to fix my POS GM truk last year was I think 5 by 2 and I think 3/16 possibly quarter,with a very heavy web build up. It worked like a dream to rebuild that rusty krap GM put on there . I bought that 5" for under 50 buks last winter for 12'. If I was going to set something up I would use that stuff and then weld some rod along the webbing to make it even stronger .
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2016 FORD F-150 (A50854)
2016 FORD F-150...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2012 John Deere 7230R (A51039)
2012 John Deere...
