Can I use angle iron this way
   / Can I use angle iron this way #21
I'd suggest going with C channel - I made mine out of C channel and even hanging weight off the tips I haven't bent them yet. My loader doesn't have a massive lift capacity (but more than a 318!) so you'd be fine with it and the weight difference between the c channel and angle should be minimal.
E.
   / Can I use angle iron this way #22
E.
G
That' s what I would think too. You will find that stuff fairly inexpensive at a steel fab outfit. The stuff I got to fix my POS GM truk last year was I think 5 by 2 and I think 3/16 possibly quarter,with a very heavy web build up. It worked like a dream to rebuild that rusty krap GM put on there . I bought that 5" for under 50 buks last winter for 12'. If I was going to set something up I would use that stuff and then weld some rod along the webbing to make it even stronger .
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
RIGID TOOLBOX (A50854)
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2009 KENWORTH T800 (A50854)
2009 KENWORTH T800...
2006 International 4400 LP Crew Cab S/A Heavy Haul Truck Tractor (A49461)
2006 International...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
