Can I retrofit 540/540E on a 5520 JD?
   / Can I retrofit 540/540E on a 5520 JD? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
The other post regading a creeper gear on a 5025 series has me wondering if I could install a 540/540e on my 5520. I now have 540 only.
It sure would be nice for mowing and some other chores. Any idea on this?
   / Can I retrofit 540/540E on a 5520 JD? #2
per Deere -
Solution Number: 59577
Solution Summary: Can a tractor be field converted to have 540/540 Economy PTO?
Complaint or Symptom:
Problem or Situation:
Some customers/dealers may order a tractor and decide that they want 540 Economy PTO or the tractor is ordered with the incorrect option code.
Solution:
540 Economy PTO cannot be field installed in a transmission. The only solution to this problem is to order/find another tractor with the appropriate options.
5520, 5310, 5410, 5420, 5510, 5210, 5320, 5220
Thanks for that information. I couldn't find anything but it looks like you found some way to access JD for questons?
For those that don't know, 540/540e, in which the higher horsepower tractors have a "gear" that allows 540 rpm at a much lower engine speed' seems to be the way to go. I'll bet it's commonplace in a few years. Saves fuel and wear and tear.
Thansk again.
   / Can I retrofit 540/540E on a 5520 JD? #4
For me, it means 1700 RPM vs. 2400 RPM...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
(4) 16" 8 LUG RIMS (A54756)
(4) 16" 8 LUG RIMS...
2008 Ford Focus SEL Sedan (A55853)
2008 Ford Focus...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
John Deere 6120E (A50323)
John Deere 6120E...
2025 ETNYRE BLACKHAWK RTN55TD3 LOWBOY TRAILER (A51406)
2025 ETNYRE...
