Can I retrofit 540/540E on a 5520 JD?
   / Can I retrofit 540/540E on a 5520 JD? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
The other post regading a creeper gear on a 5025 series has me wondering if I could install a 540/540e on my 5520. I now have 540 only.
It sure would be nice for mowing and some other chores. Any idea on this?
   / Can I retrofit 540/540E on a 5520 JD? #2
per Deere -
Solution Number: 59577
Solution Summary: Can a tractor be field converted to have 540/540 Economy PTO?
Complaint or Symptom:
Problem or Situation:
Some customers/dealers may order a tractor and decide that they want 540 Economy PTO or the tractor is ordered with the incorrect option code.
Solution:
540 Economy PTO cannot be field installed in a transmission. The only solution to this problem is to order/find another tractor with the appropriate options.
5520, 5310, 5410, 5420, 5510, 5210, 5320, 5220
Thanks for that information. I couldn't find anything but it looks like you found some way to access JD for questons?
For those that don't know, 540/540e, in which the higher horsepower tractors have a "gear" that allows 540 rpm at a much lower engine speed' seems to be the way to go. I'll bet it's commonplace in a few years. Saves fuel and wear and tear.
Thansk again.
   / Can I retrofit 540/540E on a 5520 JD? #4
For me, it means 1700 RPM vs. 2400 RPM...
1986 BARKO 160A KNUCKLE BOOM LOG LOADER (A52705)
1986 BARKO 160A...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
2018 JLG 450AJ CLEARSKY MANLIFT (A52705)
2018 JLG 450AJ...
Black Metal Roof Panels (A55758)
Black Metal Roof...
UNUSED GRASSROOTS IMPLEMENT 4' BOX BLADE (A54756)
UNUSED GRASSROOTS...
Galvanized Livestock Gates - (6x Total Gates) (A55301)
Galvanized...
